Gee, I should have read more of the thread.......
"Accuracy", when it comes to clocks in CD players is not worth diddly-squat. Low phase-noise and jitter are important. They kinda go hand-in-hand, but it is possible to make a low-phase noise oscillator and then screw it up when you turn it into a square wave, and the jitter is lousy.
The practice of ovenised clocks has not disappeared. Just isn't always needed, pracitcal, or economical.
Like in a CD player.
Jocko
Jocko
Jocko Homo said:Low phase-noise and jitter are important. They kinda go hand-in-hand, but it is possible to make a low-phase noise oscillator and then screw it up when you turn it into a square wave, and the jitter is lousy.
Jocko
So, as the original idea of this thread was 'what is the best performing clock', what is the best low phase-noise oscillator and what is the best way of turning into a square wave without 'screwing it up'?
I also find it hard to believe that 'accuracy when it comes to cd players is not worth diddly squat.' I have a xtal from a cd-p of 33.8688Mhz. I also have one of 33.000Mhz. Are you telling me I could exchange one for the other without any effect?
Andy
Andy
In this case doesn't the xtal frequency need to be a integer multiple of the cd format ? (I don't think 33.000MHz is)
Accuracy, and precision.....
I always got pulled up at university for mixing them up!
http://www.flatsurv.com/accuprec.htm
http://en.wikipedia.org/wiki/Accuracy_and_precision
Kind regards,
Ashley.
You should note that not all CDPs play at the same speed.
My Panasonic portable CDP plays faster than my Sony DVD. There are even differences between multimedia software on computers.
As previously stated, back to the plot...
Who has the gear to compare the different clocks mentioned? Anybody? I'm talking about actual measurements. Or has some one done it already.
Mike
Mike
two Klipschorns and two rats
Hi Mike I have two Klipschorns and two rats, so much about gear. (BTW did Stradivarius had measurement gear?)😀
Mike Gergen said:As previously stated, back to the plot...
Mike
two Klipschorns and two ears
Uh huh uh typo-pipo: Correction I have two Klipschorns and two ears, and I am not van Gogh
Andy
in your particular example you will hear it, but when we stay within the redbook spec (+/- 100 ppm), no difference can be heard.
To clarify, this is about static errors, where we use ppm's. It strikes me that some commercial clock suppliers still specify this as being 'the" major specpoint of their clocks. Others try to convince you using a spectrum analyser measurement where 100 kHz (!) resolution bandwidth is used......
Lower jitter = better
However, at a certain moment we get into the ps range, and things then are hard to measure but still audible.
Similar clocks may sound different as the jitter spectrum differs. In addition, not all DAC chips react in a similar way to jitter.
best
As for performance, in terms of phase noise........it isn't that simple. It will have a frequency distribution (did anyone read the link on phase noise?) Some will say close-in noise is important; others will say absolute noise floor is.
When it comes to "not screwing it up"........
Well, hard to make things idiot proof, as idiots are so damn ingenious. One sure-fire way to muck it up is to stick it into a '04 gate, and use the other 5 gates in the chip. 6 signals.........one ground pin and one supply pin.........6 dB PSRR at transition.............nope, not a good idea. But one that you see all the time.
Accuracy means it can be......I forget............+/-500 ppm to meet Redbook. So, no, 33 MHz can't sub for 33.868.8 MHz. It can be off several kHz, and most people can not tell a difference.
If it wobbles so much that you hear pitch-bending..........then you most likey don't have a crystal oscillator. Hard to make one drift that much, that fast.
How to measure..........? Read the link. And, yes, I can make those measurements. Although I do not have data on any clocks other than my designs, because I don't care about other designs.
Especially Elso's!!!! [joke]
He knows why...............
Jocko
Jocko
Uh...........may have been in another thread. Senior citizen moment. Again.
Yeah...........here it is:
http://www.diyaudio.com/forums/showthread.php?postid=782617#post782617
Heh, heh...this thread was rather amusing at one time. New expert on the block wanted to pound his chest.
Pounded with rotten tomatoes, more like!!!!!! "Clan Abruzzese" strikes again, eh?
Jocko
Jocko
I am sort of in the dark on this clock thing and just stumbled onto this thread. Maybe this is a good place to ask this, as something good may come out of it...maybe the 'best' clock!
something I've wondered for a while...
What If I took a ... say ..15Mhz rubidium (stratum 2?) telco oscillator and used a frequency divider? Is this an 'off the wall' idea or is it feasible with good/ great/ incredible results??
...or maybe just a high quality ~1 gig oscillator used in microwave transmissions ??
regards,
Marc
regards,
Marc
It has been suggested before..........many times.
How are you going to get 11.2896 or 16.9344 or 33.8688 MHz out of any of those???????
The "high quality" microwave "bricks" we used to use had a comb generator and a multiplier in them. Eventually, Fujitsu came up with a DRO (dielectric resonator oscillator) that did not use a crystal. They all worked ok for FM, but trying to pass 256 QAM with them was a nightmare.
That is why they invented fiber optics. Got rid of microwave radios and the guys like me who designed them. Hello unemployment line...........
Jocko
Jocko
Just a little question, while being in the clock topic : Is it easy to get 11.2896MHz from 33.8688MHz? Will I need VCXOs and lots of things like this or it can be made with simple logic?
DragonMaster said:Just a little question, while being in the clock topic : Is it easy to get 11.2896MHz from 33.8688MHz? Will I need VCXOs and lots of things like this or it can be made with simple logic?
Hi
If you want low jitter, it ain't easy. Indeed you need a PLL circuit and VCXO.
Divide by 3 starting from 33.8688 MHz possible ?
best
Guido Tent said:
Hi
best
Arrrgh! I wonder how many MHz I will need to make this easily...
Jocko Homo said:It has been suggested before..........many times.
Jocko
How?? Beats me! That's why I asked.
Geez Jocko..sorry to see your microwave experience. Microwave is still a majority of my job and sometimes I think it's why I still have one
Thanks.
Division by 3 is certainly possible but will the clocked device accept a 2:1 mark/space ratio?
Well, I'm surprised.
4 pages into this thread and nobody has posted a comment along the lines of "X is better than Y because of Z".
Which leads me to wonder: is there any real (noticable performance) difference between an XO2, Trichord4 or Kwak? Or does it come down to implementation? Ie, avoid shoving it through a '04.
Hacker said:Well, I'm surprised.
See post 5
- Digital Source
- The 'best' performing clock?
