That's the one. One detail I should have added earlier, part of the debate on the radio boards was whether the failures were due to migration or over-voltage.
Cap manufacturer contact
Guys,
Not finding the Polypropylene caps you want. I put an enquiry for 900V DC rated Pulse Grade PP caps which I've used extensively for power supply upgrades to the New Zealand manufacturer. Most coutries have pretty good exchange rate to the NZ dollar. Note that they quoted me in Australian dollars, divide by about 1.2 for NZ dollar price. They have a website and you can view the various capacitors they make. If you can't find what you want get them to make them for you.
http://www.metalect.co.nz/product_index.htm
The ones quoted below were Series 600 Type C
http://www.metalect.co.nz/series_600.htm
They said:
"Hello Ian
I have attached a quote for the capacitors you are inquiring about.
We do not have a minimum order quantity for these, however to make it worth
our while we would really need to make 50 of each. We do not keep the cells
in stock so would need to wind some up specially for your order. Delivery
would be approximately 2 weeks from order and we would require payment in
the form of a company cheque or telegraphic transfer prior to dispatch. If
payment is made by telegraphic transfer there will be additional
administration charges.
I look forward to receiving your order.
Wendy
Metalect Industries (NZ) Ltd
108 Riri Street
Rotorua
New Zealand
Phone 07 348 0286
Fax 07 347 9707
Dear Ian
Thank you for your enquiry, we are pleased to offer you the following.
Description Code Quantity Price Discount Amount
1.0Mfd 900vDC dipped cell only capacitor 1.00 5.79000 5.79
2.0Mfd 900vDC dipped cell only capacitor 1.00 6.05000 6.05
5.0Mfd 900vDC dipped cell only capacitor 1.00 6.26000 6.26
10.0Mfd 900vDC dipped cell only capacitor 1.00 6.98000 6.98
The above prices are in AUD and do not include
GST or freight
We trust you find the above meets with your approval. If we can be of further assistance, please do not hesitate to contact us.
Regards,
WENDY
Friendly folk, making great caps.
Ian
Guys,
They said:
"Hello Ian
Wendy
108 Riri Street
Rotorua
New Zealand
Phone 07 348 0286
Fax 07 347 9707
Dear Ian
GST or freight
Regards,
WENDY
Ian
Hi All,
I am in the market for some inexpensive caps and have a couple fo basic questions:
1. I found some russian PIO caps on aBay. They don't identify the positive and negative leads, so should I assume that these are non-polarized and I don't have to worry about the direction of installation?
2. Anyone familiar with Nippon capacitors? The one that I found are snap on; I will assume that I can solder onto it since I don't have the correct snaps.
Phil
Phil
Just be consistent!
Non polarized caps don't have any marking as to cathode or anode. Just observe a signal path as an arrow in its flow direction and mount all the non polar caps in this direction. The SBC716P line of capacitors from Antique Electronic Supply and others ARE GOOD. They have solid copper leads. Madisound had some GE polypropylenes up to 10 ufd, 600v, but they are large. The PIO Russians are about the same as the old Vitimin Q which are very good caps if you can find them. You can also find Russian Teflons from time to time on ebone. I bought mine from Ginteras Sikenas in Litheania and he has GREAT SERVICE. grh😀
Also from a UK manufaturer, please look at these....
from Ampohm http://www.ampohm.co.uk/
they work me out about $15 for 2 over here through RS components.
Am I just stupid or is there no datasheet on these caps?Nordic said:Also from a UK manufaturer, please look at these....
from Ampohm http://www.ampohm.co.uk/![]()
Capacitance Tolerance ±5
Temperature Range -40 to +85°C
Dissipation Factor (At 1kHz-20°C) <0.001
Designed for high performance audio systems
Low ESR and low self inductance
High stability with respect to both temperature and frequency
Ideal for use in loudspeaker crossover networks and valve amplifiers where pure sound is at a premium
Realy nice sound
Realy nice sound
Just read the thread... I need 250nF (600V) coupling caps and reading this thread stumbled across polystyrol caps. I can get 47nF (630V) for 2,85€ per 10 pcs. Is it possible (recommended) to parallel (in my case 5 of) them?
Or should I rather go for a single Wima MKP10 or such?
Mundorf Supreme or Russian Teflon are about ten times as expensive, so I would rather not have to buy them....
Has anyone heard of Siemens Icotron Capacitors?
I've got a bag of 50which have the following ratings:
Capacitance - 2.2 uF/pF
Tension - 250 V
Toerance - 10 %
Ref Nr, Ce - 5051
Quantity - 50
They measure near 2.2uF so ignore the/pf.
I have not been able to find out what the construction is, Teflon,not likely, Polypropylene, Polyethylene, ???
It looks like they were made in San Polo Brazil.
Thanks for any info.
Tension - 250 V
Toerance - 10 %
Ref Nr, Ce - 5051
Quantity - 50
How large are the caps?
2u2 250V 10%, I'd guess are a MKT, the 250V 10% makes me think mains voltage.
You might have to emal them?
Icotron Industria de Componentes Eletronicos Ltda.
Icotron@siemens.com.br
James
James
Best under $20? Yech, should be best under $1!
Easy, Cornell Dubilier DME series. You'll get a 0.1uF 400V for under a buck. Convienient size, too.
And tube coupling caps don't even draw current. Induction heater coupling caps do.
http://myweb.msoe.edu/williamstm/Images/PCBs4.jpg (bottom left)
When you're coupling 80A, you need quality caps. 20 in parallel (4A per) and they don't warm up at all.
There are some pretty damn cheap MKPs, too. The gray boxes there were like 10 cents each from Allied. Those are 0.1uF 275VAC MKPs from Illinois Capacitor. (I don't recommend them for tank capacitors, they aren't good for more than 1A each.) The biggest problem with MKPs is they usually have trimmed leads no good for point-to-point.
Tim
Tim
Tim
Here's info:
http://www.cde.com/catalogs/DME.pdf
I have tried russian aluminiumfoil in oil, teflon capacitors, wima MKP / FKP. I can hardly hear any differences, I prefere wima FKP 2 capacitors ( cheap and way better than "audiophile" capacitors which add distortion ).
716P series "Orange Drops" are the least costly coupling caps. that sound OK. A very nice price for a film and foil part.
x2 🙂
- Design & Build
- Parts
- The best Coupling cap (under $20)
