how to do you manage output offset voltage ?
i can see a good spot for a pot to set the bias... but i can't see how i can trim the output stage for 0 volt out.
At any rate... seems great !
Hi
You could use pots in place of R8/R9
Best regards
Sébastien
i think i am gonna build it out...
seems quite good on paper to be worth a test.
what do you think ?
I replied to your email, I think that the version has TTA is good to achieve, I will do in September
sorry mate.. didn't get any from you on email.
i will drop again my address on pm.
thanks
M.
A question for Mike Rothacher,
I saw the V-FETRON on your website AudioMaker | DIY Audio Projects & More, was it successfully completed?
I cant delete my pic!
After the good result obtain with my hybrid Circlotron design using interstage transformer I would like to create a pure solid state design.
I have simulated many design and I see this characteristic, with the same bias the first keep 108mA and the others only 20mA.
This mean that the first design turn off the output device much later.
- The Amazing Fet Circlotron by Mike Rothacher
