When you consider the cost of the inductor against the cost of the thermistor/resistor route, I choose the later.
Love that Guinness!
Love that Guinness!
Why don't you just ask Nelson Pass where he buys his thermistors from? or just use 5 watt power resistors of the same value. They will provide the same result, low noise and ripple.
a) Nelson would say Digikey, but its not so easy to order from Germany...
b) for pi filters power resistor may be ok, but i need thermistors because my fuse blows every 20 times or so i switch my ZEN V2 on.
so anyone who could help me and Tazzy, (i´m glad to see i´m not the only one with this prob) out?
There is an alternative, I can provide you with a surge limiting circuit, which places a 10 Ohm 25 watt resistor in the primary of the transformer for about 0.5 of a second. I have been using this type of surge limiting for years and it works very well with toroidal transformers...
It added a bit more complexability, but nothing you can't handle...
I even have a pcb layout
Has anyone got anymore Giunness, Hickupp!
Saint: with a relais?
please post schematic.
isn´t ist more complex and expensive than finding a way to optain this devices in europe?
----- and: if we are filling this thread with off topic disussion now : please take a look on my telequipment D52 question in "tubes"
It depends how many phone calls you make, The surge limiter is not expensive. I will post the schematic tomorrow. Its 1.00am here and I need to get some sleep...
Cheers
Anthony E Holton
Besides there's not more Guinness
Cheers
Anthony E Holton
I got some NTC's from www.Conrad.nl, as far as I know there is also a www.conrad.de ! They are Siemens (german!!!) NTC's, and available in different ohm values. I use them, and they work! My Aleph 4.5 😎 (higher bias) is working perfect on them!
just found them: http://www.produktinfo.conrad.com/cgi-bin/dlc/dlc.cgi?art=468037&lang=DE
Edwin
thank you Edwin, I found NTC´s at Conrad and Reichelt, but i´m not able to figure out wich one is right. I ordered one and as i wrote it was wrong, it exploded.
Even it was very small, and this CL-60 on Nelson pics are much bigger.
Which one is compareable to CL-60? B57237-S100-M ???
this would be Artikel-Nr.: 468045 - 62
Till,
this is the datasheet for CL-60: http://www.thermometrics.com/assets/images/cl.pdf.
Found something very similar at Bürklin: http://www.buerklin.com/gruppen/KapE/E111900.asp.
Hope this helps.
Grüße: Holger
Hope this helps.
Grüße: Holger
till said:thank you Edwin, I found NTC´s at Conrad and Reichelt, but i´m not able to figure out wich one is right. I ordered one and as i wrote it was wrong, it exploded.
I used two 5 ohm's in serie. Does the same as one of 10 ohm however they share the load 😉
Do not switch the amp on and off without at least 15 seconds between off and on. Else the NTC did not cool off and they do not supress the rush when they are hot.
And yes, the 468045 - 62 is the same as a CL60 !
Edwin
I've got the feeling that a S100-M is a bit to small?
I might be mistaken though...
Edwin? Which ones did you use?
I'll be cracking open a draft-widget can of Boddington's
Boddington's is alright a bit wheaty with a sour after taste. I hope you pour it into a frosted glass and drink it at 10 Deg. below room temperature.
Now myself, I like Old Speckled Hen, Hobgoblin when I can get it and Fiddlers Elbow.
Cheers mate.
As far as inrush Current Limiters go like the CL-60, I find putting them on the primary lead of the Secondaries to work more effectively. This allows the Transformer to stabilize much faster but still limits the curent drawn by the charging curve of the filter caps. As a dual secondary transformer has two primaries and two commons, you will need two device per transformer.
You mean on primary
Nope one on each Secondary, as they are naturaly 180 Deg out of phase.
How would you do it when using 2 bridges without common ground?
If you refer to the Plitron reference card that comes with thier transformers you will notice a dot indicating the Blue and Red leads are "Hot". That is where the Inrush limiters should be in a dual bridge configuration.
Anthony
- The Aleph-X
