thats a big crane
IIRC that barge capacity was 15,000 tonnes.
Only the steel hull had any value, the suoerstructure was old wood with probably no value.
There are no drives on the barge. These are just great big ocean trailers. They haul wood chips.
Sorry we are getting away from cranes. My bad.
Reactions: Subuckethead
Perhaps the biggest crane failure...cranes worldwide are working hard, but nobody notices unless they collapse, in spectacular fashion.
"Big Blue", a monster crane moving an 11.000 square foot, 500 ton pre-made roof section for a Milwaukie sports arena...Ironically, a safety inspector was on-hand to record & document the lift.
-----------------------------------------------------------------------------------------------------------------------------------------------Rick...
Yes Big Blue got a lot of coverage.
I was looking up what the counter weights weight, not knowing it collapsed.
233-foot, 4,600-ton
Crane can lift more than 2.3 million pounds 😵
I didn't find gross weight for the counter balance.
I'm going OT for a second, because that'sa big excavator. I'm pretty sure not the biggest.
Largest mobile excavator (Caterpillar 6090j is one thing, but open pit mining scoopers is a whole ‘nother story.
Bagger 293 still the champ, I think?
Liebherr will sell you fridges, freezers and wine coolers in any size you like from table height fridges via twin and triple door full-height American style ones, ones for commercial and laboratory use of any size to deep-freeze and refrigeration systems for industrial warehouses.
You want to see the hole it helps digging!
They use 4 or 5 of those excavators digging to a depth of 500m with a surface of 84 square kilometers. When they stop digging in 2035 half of it will be filled in and the other half will become Germany's 2nd largest lake behind Lake Constance. It will take 60 years to fill with water.
