Thanks Tom
Don't know what was going through my head regarding any noise on the THAT Receiver inputs. Sorry you had to explain the obvious. I seem to learn so much more building things rather that getting them assembled.
Got the board today. Looks like the THAT 1646 chips are back ordered at Mouser 🙁
Mike
Mike
According to the Mouser delivery schedule, the wait shouldn't be too long, though. They have three deliveries in January. The last one is on the 15th, so if you place your order today you should see your THAT1646es soon.
Tom
Tom
I finally got the board populated. I had my own +- 15 volt power supply, so didn't populate any of the components on the last page of the instruction document. If anyone else goes this route, I found it much easier to install the terminal block to j5, solder jumpers to d9 and d11, and connect the PS outputs to the j5 terminal block.
My testing didn't go as planned, but perhaps I have misunderstood the 6 db gain of the THAT Driver. I applied a .25 volt sine wave to j1, and expected a .5 volts across pins 1 and 2, and .5 volts across pins 1 and 3 of j2. Instead, I measured .25 volts. I did measure .5 volts across pins 2 and 3 of j2.
Does the 6 db gain refer to the voltage across pins 2 and 3, which are the inverted .25 volt sine waves?
Thanks, Mike
Thanks, Mike
If you apply 100 mV to the input, you should measure 200 mV from pin 2 to pin 3 on the XLR.
Tom
Tom
I have finished my build of the THAT driver. I use it between my preamp and mod86. There seems to be a good deal of synergy between the Neurchrome devices. The sound I am experiencing is very clearly greatly improved. I am highly satisfied and would recommend the THAT driver to everyone who are using Mod86 and are currently using it Single ended.
Thanks Tom!
Thanks Tom!
I would attribute the "good deal of synergy" to minimal distortion and noise end-to-end. To borrow a hackneyed audio reviewer phrase -- "veils removed"
Not anymore 😉
Thanks for your comment, I am sure you are right.
I can't stress enough how much of a difference adding the THAT Driver to my system has made. Amazing, I really mean it. Everything is better. Imaging, punch whatever.
Ah darn, too late. Anyone got one board left they're willing to sell?
The DIFF PRE 8x2 is four THAT Receivers and one THAT Driver with some relays and a volume pot in between. I have four board sets left... 🙂 You can find them here: Differential Preamp 8x2 | Neurochrome :: Audio
Tom
Tom
Thanks for the thought Tom, unfortunately I can't use the DIFF PRE for my intended use.
Will you be making another batch?
No. The THAT Driver used the LME49710, which has been discontinued by TI for over two years now. It was never a big seller anyway.
I may offer a universal buffer at some point. Maybe in the late spring or over the summer. The idea would be to have a high-end buffer that could replace both the THAT Driver and the THAT Receiver. It would be a fully assembled circuit module; no bare board option. It'd be a stereo board featuring better performance (lower noise) than the THAT boards.
How much would you be willing to pay for such a module? $99? $149? $199?
Whether I'll offer such a module for sale depends a lot on whether I can make the finances work.
Tom
Hi Tom,
For me the $99 price point is good but could go as high as $149 to not have to sacrifice design. I know $99 could potentially be tough to achieve with such high quality design.
Do
Do
For a fully assembled module, $149 doesn't leave much for me and $99 even less if any at all. I could probably do an SMD-prepopulated option for $99. You'd then have to add connectors and a few other leaded parts.
It all depends on the complexity of the circuit. Can I expect you to provide your own ±15 or ±18 V supply? Or will the universal buffer need to have on-board regulators?
Tom
Tom
- Vendor's Bazaar
- THAT Driver :: A minimalistic differential driver / preamp with 0.000021 % THD
