Test tone voice coil centering for refoaming
I'd like to center my voice coil with a low-freq test tone without desoldering the leads from the woofer. I removed the driver with leads still attached (see photo) and connected leads directly to the driver but it does not move the driver. I tried frequencies form 5-500 Hz. Unless the voice coil is broken, I can't understand why this would not work? Why wouldn't this work?
Did the woofer sound before?
Measure its DC resistance with a multimeter, it should be around 60 to 80% of nominal impedance.
Open/infinite is NOT good, of course.
And go through an amplifier, as mentioned above, signal generator will not drive it by itself.
Hooking to the external terminals worked. I was able to use a 10 Hz sine way without attenuation through the crossover which surprised me. Not sure why it did not work when I bypassed the crossover and hooked direct to the driver.
