Building another SSE! Went to get another Temco Motor Run Cap, but they appear to be out of stock everywhere. Would this one work as an alternative? https://a.co/d/0S0hZmo
Is there a better option out there? Something perhaps better sounding (if this component affects sound) or better looking?
?? look through their inventory of motor run - use "MFD" with search engine
Their prices and service are very good
I don't know your application's requirements so 370vac might not be enough ?
https://www.supplyhouse.com/Titan-Pro-TRC100-100-MFD-Round-Motor-Run-Capacitor-370V
Use this one.
https://temcoindustrial.com/ac-elec...acitor-rc0162-80-5-uf-mfd-440-vac-round-hvac/
Just use the 80uF section & leave the 5uf one disconnected.
It's the same size as the 100uF one & the difference in capacitance is not going to be meaningful at all.
Is there any reason not to use the one in my first post? https://a.co/d/0S0hZmo. It's cheap, and easy to get.
Or alternatively, this one? : https://www.grainger.com/product/DAYTON-Motor-Run-Capacitor-Round-6FLP2
That DAYTON brand seems to be nearly identical in size to the original TEMCo.
Other than price & temperature rating, no.
take a look at this one from Mouser too
https://www.mouser.com/ProductDetail/KEMET/C870CG36100AA0J?qs=pqRVuuzkf6aojq2BqdFF2w==
Any of the caps mentioned here will work electrically. I got some big caps several years ago on Ebay and they do have an ugly bolt thread mounting stud sticking out of the end opposite the terminals. Attempting to cut it off did not go well. The cap passes very little AC current in amplifier use, so it generates virtually no heat on its own. The relatively shiny can reflects much of the radiant IR heat from the tubes, so there is usually no need to paint it unless you want to. The can should be grounded as some residual charge can build up on the can if left floating. I often use these across the output of my old Fluke bench supply to improve its ability to put up with my abuse. An ungrounded can will give you a noticeable shock even if the bench has been turned off for a day or so.
Thanks George. I ended up going with the Dayton can, as it seems identical to the TEMCo, even in temperature resistance. I may try giving it a coat of black gloss enamel (save for a section of exterior metal in order to ground it), depending on how it looks in the forthcoming chassis.
- More Vendors...
- Tubelab
- TEMCo motor run caps out of stock. Other options?
