tell me what do you think
Ok guys ya'll been a big help so I finally came up with some information what do you guys think. I will be building 21 inch hog scoop with 18sound 21LW1400 driver.
the speaker described in your input screen has a "short" 1.25 meter path. With the speed of sound ~343M/s its quarter wave is 343/(1.25*4) ~69Hz.
Below is the input for an 18" driver hog scoop and its path is roughly twice of your input
Can you post a drawing or link to a drawing of the cabinet you want to examine with hornresp ?
scaled 1.17:1, I get about a 2.8->2.85M path for a 21" version - roughly a 30Hz 1/4 wave.
one the model is established, 21LW1400 can be plugged into hornresp along with the scaled cabinet's width - then one can use a "wizard" (!) to examine the effects upon response from narrowing the whole cabinet - it may look better in some instances
FWIW, did a quickie 18sound 21LW1400 parabolic TH tuned to ~40 Hz to 'hit/slam' at 50 Hz [or does it need to be higher], so considerably smaller than the 18" at ~237 L net and of course won't play as loud.
Note: driver may not physically fit, so S1 may need to be bigger.
GM
  • 18S21LW1400_hogs.txt
GM - that's a fat little hog :D lots of punch - should handle 1500W peak with ~11mm @~56Hz movement. How would it translate to wood for LION SQUAD SOUND ? How might it sound?
21LW1400 would kinda work in a Karlson (lol) - scaling Acoustic Control's 115BK by 1.4
makes a K-coupler about the size of GM's parabolic TH - but tuning is somewhat below 40Hz
so needs to be tuned higher for punch
Semi-inductance is going to change the response of that horn a bit. I've modified the sim to include some semi-inductance parameters I derived from the published impedance curve for the driver. They're not totally accurate (deriving them using ZMA data would be much better), but better than not using them at all.
Hi Brian and GM - I was looking at scaling the posted hog scoop schematic by 1.17:1 for OP's 21LW1400 but goofed and entered things "ND-wise"
might you re-arrange this expansion for proper TH sim ?
that lossy LE sag looks right - (this is a 4.5" coil ?)
  • goofedhog21.txt
