The tuning frequency actually is the impedance minimum between the two peaks and is 30 Hz. You need at least a 5" port, length around 10". 🙂
Yes misread that on the tiny screen on my phone.
Thanks for the further info guys. looking at some other woofers here. Specs are as follows:
Re: 6.3 ohm
Fs: 41.8 Hz
Qts: 0.54
Qes: 0.655
Qms: 3.08
Vas: 58.079 liters
Xmax: 6.5 mm
also a "Bass guitar" type woofer, how well does that model out in this sort of alignment? I can adjust box-size up or down depending and was actually considering trying a double reflex, as that seemed to have some nice benefits without too much downside.
Re: 6.3 ohm
Fs: 41.8 Hz
Qts: 0.54
Qes: 0.655
Qms: 3.08
Vas: 58.079 liters
Xmax: 6.5 mm
Well thanks for the good info, it's really helped inform my decision process on drivers and pursuing the project. I will be tackling the build here over the next couple of months.
