I've recently completed refurbishing a Technics SP-10 Mk2, along with a custom plinth. I documented the project for anyone undertaking something similar.
Click here for link
Mike
Click here for link
Mike
Click here for link
Mike
Thanks. Superb project and detail. Helps fellow SP10 owners quite a lot.
Cheers
Very handy, Mike. Thanks for such a good job of documentation.
Two comments:
- unless I read past it, I didn't see you mention where you got your dust cover.
- You mentioned the hold-off of the 32V supply when the turntable switch if flipped. I recently measured that on my unit and the 32V is delayed by about 20 ms relative to the 5V supply (resistive loads). At 20 ms, the 5V is not fully up either, but the holdoff circuit releases and the 32V ramps up. I think this is enough to let the 5V supply get into operating range of the circuits before the 32V finishes ramping. I should have taken a scope photo but didn't.
Two comments:
Brian-
Thanks for your notes.
1. I didn't provide a link for the dust cover because although it was relatively inexpensive, I wasn't completely happy with the supplier. The cover wasn't exactly square, and there are some less than perfect joints at the corners. In short, I don't have a supplier I can whole-heartedly recommend.
2. The 32V supply hold-off in the original design may just be a precaution. I've seen other replacement supplies that charge both the 5V and 32V at the same time, no problems. Mine gets the 5V up to speed a bit quicker.
Best regards,
Mike
Best regards,
Mike
Click here for link
Mike
Had a quick scan of your site - especially the SP10 pages. Very nice work.
I can't speak for the MKII, but I know on the MK2A it is necessary.
