technics sl-1600
Hi, does anyone have a owners manual for the technics 1600? I just got one from a friend and would like to know how to set it up. Also does anyone know if the denon 103R cartrige would sound good in this table. Thanks for your help.
John
I have an SL1700 which it the semi-auto version of your 1600. You can get the SL 1700 Manual here. . I have always used a Grado MI cartridge with carbon fiber headshell. I use a machinist level on the plenth left/right-fore/aft. The feet are adjustible but ideally u you set it on a granite surface plate and adjust the shims under that. I used a Audio Tecniques protractor to set the cartridge angle. I run the balance at about 1-1/4g to 1-1/2g using the stock arm
