Team Cactus 7kw
Ok found a problem In the power supply section Resistor R166 is very badly burnt anyone know the value of this?
Would an output inductor cause squeal on the outputs? I noticed when i recieved this amp in for repair that 1 of the output inductors was loose and had been removed from the board at one point when i get the squealing that same inductor also squeals . Or could it possibly be something else?
Only thing i can see is that inductor when i tap it it makes it worse and i can hear the inductor squealing and it sounds like its popping .
If i remove it from the board amp will still produce audio but the output still squeals is that because its removed or because there is another problem?
