Team Cactus 7kw
I got this amp in for repair and it had blown outputs and driver ic's I put new outputs in the amp Output driver board is still out of the amp.
Amp is stuck in protection mode Heres the voltages i have.
LM293
1:0.16
2:13.86
3:5.05
4:0.00
5:1.38
6:3.97
7:0.17
8:13.87
TL494
1:0.06
2:5.05
3:4.90
4:5.02
5:1.49
6:3.73
7:0.00
8:13.86
9:0.00
10:0.00
11:13.86
12:13.86
13:5.05
14:5.05
15:5.05
16:6.58
A1266 middle pin goes to a diode then goes to a 100K resistor then the resistor is directly connected to pin 16
On the diode that connects to the middle pin of the 1266 has 13.28 volts on both sides of it then the resistor has 13.28 volts on 1 side and 6.60 volts on the other that connects to pin 16
Heres some pics of the amp if you need pics of a certain part let me know
