I finished the box but it is pretty off topic for this thread since I used a different amp. I did use that Airgain antenna though and my range is really great (50-60ft LOS). I mounted it to the underside of the button panel which is 1/8" MDF so I think the reduction in range is pretty minimal. Thanks again for the help, here is my new thread with some pics:
http://www.diyaudio.com/forums/class-d/293497-i-built-boombox.html#post4759715
Sorry for reviving this older thread but I am attempting a similar project and I want to add an external antenna as well in the same manner that was being discussed earlier. Can someone please show me the exact solder points for the ground and signal on this board? I am confused by some of the earlier pictures. Thank you.
