TDA7293 IC
Daniel, is it possible to combine the »modular« approach with the »economic« approach in the TDA7293 datasheet? That means paralleling the output stages of two or more chips and arrange them in a class g/h (whatever it may be...) environment? Best regards!
I didn't find out. See the arrangement with 1000uF connected near small signal portion of the amp? Large signal support on a board that ought to be treated like small signal, says that it is a subwoofer amplifier... and I lost interest directly. Today, we use Class D for subwoofers, especially NXP's Class D (after you put on a real input circuit including 470R series to each input to lower crosstalk).
However, it was interesting to see the possibility of TDA7293 chips in slave mode working at up to +-50vdc (32+32vac transformer). So, a parallel output tube hybrid looks promising. Or, if you happen to have a driver chip handy. I haven't tested at that voltage, but TDA7293 in slave mode looks like bargain priced audio output fets.
Friennnddsssss !!!!
I have a new module with TDA7293.
I have a little hum 60hz, in ONE channel..
Only little and only in one channel.
Whyyyyy ?
And i have 0.014 ac in these channel.
Friends i build a tda7293 module estereo , and i have 60hz hum in one channel.
0.014v ac ,is not a lot of ac noise, but why ?
First, make ALL wires for right channel Exactly the same length and size/gauge as left channel (especially, identical left/right, input wires and dc power wires--NO left/right difference).
Second, use a battery powered source (because it can't ground loop if it isn't plugged in).
SO,
The above steps will help to find the layout fault; because, if it wasn't the wiring, then the fault is in the board layout.
For that, you'll need to post photos, using the attachment feature.
