tda2052
I've build the suggested schematic on pdf file of datasheet.
But i've the following trouble...
1) Turn on my PSU +/-24V
2) All wire connected (input/output)
The trouble is here...
I give +5v at pin3 and for a second it seems to give the right power to the speaker and immediactly after it goes at lower volume with a little tendency to give high frequency as output...
I hope to have be clear....
Some suggestions?
Are the red polarity correct?
And if it's alway connected to negative it's always in stand by....
It is likely to be something simple. Lets start eliminating possible problems.
1 make sure all cap are connected properly(polarity)
2 check all ground wiring
3 measure resistance at pins(between pin and ground)
4 C1 bewteen R1 and pin 7(not R1 and ground)
5 measure at pins 5and 7 : bewteen pins 1 and 6 and bewteen 1 and the (+) of C2
Dont connected any. Only check the resistance bewteen the pins,You know what the resistance should be.
I looked at the picture you posted everything seem OK. The only thing I see that maybe a fault is a possible connection bewteen pin2 and 3(look inside the square).
Have you built more than one?.
You make just have a bad chip. It happens.
Were is the +5V for pin 3 coming from?
