Hi All! How connect TDA1540 to I2S bus? (to PCM2706)
V vrpvrp Member Joined 2007 2007-11-14 2:58 pm #1 2007-11-14 2:58 pm #1 Hi All! How connect TDA1540 to I2S bus? (to PCM2706) ••• More options Share H Hetron Member Joined 2007 2007-11-16 10:35 pm #2 2007-11-16 10:35 pm #2 Maybe you need this: A shifter to delay to right justify and delay the left channel. This is designed for the PCM1704. ••• More options Share V vrpvrp Member Joined 2007 2007-11-18 1:15 pm #3 2007-11-18 1:15 pm #3 Not exactly. I now what it is needed to separate LRCK to each TDA1540 (to left and right channel)... ••• More options Share A Aronier Member Joined 2008 2012-04-17 5:18 pm #4 2012-04-17 5:18 pm #4 Hello, i would like to do the same: TDA1540 in my Philips CD-104 Player connect with I2S outpu from squeezebox. Do anybody know how to do this? regards ••• More options Share lcsaszar Member Joined 2004 2012-04-17 8:32 pm #5 2012-04-17 8:32 pm #5 You need a glue logic between them. ••• More options Share A Aronier Member Joined 2008 2012-04-18 9:14 am #6 2012-04-18 9:14 am #6 Ok, thank`s and which glue logic? Do anybody has make this? ••• More options Share lcsaszar Member Joined 2004 2012-04-18 8:41 pm #7 2012-04-18 8:41 pm #7 Search for "I2S splitter". ••• More options Share V vizion Member Joined 2007 2016-09-02 5:51 pm #8 2016-09-02 5:51 pm #8 Hi, What voltages are required to power the TDA1540 ? 5v -15v and -17v ? Can you get 2vrms output ? Thanks. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home Source & Line Digital Source TDA1540 to I2S connect
