TDA 1543 I/V stage education needed!!
IV and Bufferstage
Mad_K said:
Many thanks Elso 😉
I'm curious about your bufferstage; do you want to share some details?
Also, a quick question: How does it sound comparing to passive I/V?
Hi Mad_K
Funny thing is that I got the passive IV stage never working quite right. I did not get rid of the hum. I also noticed a lack of dynamics with passive conversion, also with the AD1865.
In the schematic below R3= 3k65, c2 = 3n3 and ???= ground. The non-inverting input of the first opamp is not connected to ground but to Vref of the TDA1543. First opamp= OPA604 and second opamp is the discrete buffer. Much to my surprise the OPA604 sounded better than the discrete buffer for IV. I tried almost all conceivable opamps in this position! All caps are 1% polypropylene Philips or BC Components and the resistors are Dale metalfim, yes the well-known brown coloured ones! I am extremely grateful to Audiofanatic letting me to try these resistors!🙂 The filter was calculated in a few seconds with Filterpro from Burr-Brown. The third order filter is of the multiple feedback variety and the first pole is in the IV converter. This way I could realise a third order filter with two opamps and an IV converter.
For the buffer stage that is after the IV stage see this thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=1794&highlight=
Interesting Elso, but is the value of the Vref to GND (3K3) resistor on the 1543 independent of the R3 (in your schematic) value?
I was planning to do as per 1543 datasheet, but with 3K3 to GND from Vref; is this correct? (+5VDD)
Well, I tried it and I must say that I LIKE IT ALOT 😉
I used the opa2604 and 1K2/3n3 and 3K3 from Vref. I have about 2,1V on the output.
I will definately make a proper version and experiment with different (single) opamps etc..
All the things I felt the passive IV lacked are now in place; dynamics, bass slam and a generally more interesting/musical presentation :smash:
Thank you for the 3K3 value Elso 😉
BTW -if I want more gain; could I just recalculate the R+C value in the feedbakloop, or are there other matthers to consider?
With the 1K2 I figure I get about 1V RMS out.
R and C in IV feedback
Curreently I am using 3k65 and a 3n3 cap as the R & C value.
:idea:
Despite the ugly looks I have heard DAC's with waveforms like that without remarking much negative ( sonically of course ). I did remark that my efforts of making it better resulted in a less good sounding but better measuring DAC ....
Maybe human ears have a built in integrator ? 😉
Datasheet
tonitze said:
Elso,
can you please explain again how to connect the 3k3 resistor. Is it like this; ground=3k3=vref=non-inverting input
or vref=3k3=non-inverting input and non connecting to gnd?
getting real confused😕
Thanks.
toni
Hi Toni,
Yes it is in the datasheet of the TDA1543! They call it a optional resitor and the only omission is they give no value...
Today I tried removing the 3.3n cap parallel with the feedback resistor on my tda1543 active i/v using op-amp and it sound good. What are these cap for. Is it for filtering or something?
I happen to come across tips by KYW on tda1545a active i/v using op-amp as per datasheet and I applied it on my nos tda1543 and it sound good. Am I doing the right thing here?
Toni.
