G300v33BTL and G300V33PBT module completed!
PROAUDIO TO HI-FI VERSION
STABLE AND EXCELLENT SOUND
Very stable version, shorted output together anytime no problems.
Dynamic limiter support,
DCP /OCP/ UVP/OTP protections, even POWER LEVEL control system added, this function can make the module RMS power about 400W total.so the chip can run under safe conditions.
Key benefits
ü Backup DC supply system, suit for solar or car system application.
ü A wide set of features for plug and play implementation into applications such as active speakers or proaudiosystem.
ü Black-box design, module have good heat dissipation and better EMC performance.
ü Advanced protected function against short circuits, overload and overheating and includes on-board fuses and EMI filtering that provide a CE and FCC pre-approved design.
Key Specifications
.POWER OUT:
G300v33BTL 2×200W/ 4Ω@1%THD+N /2 BTL MODE
G300v33PBT 1X350W /2 Ω @ 1% THD+N /1PBTL MODE
.FREQUENCY RESPONSE: THD+N ≤0.05% / 20-20KHz / <1dB/1W
.INPUT SENSITIVITY: 0dBV(1Vrms/BAL input)
.S/N: 98dB(AES-17/A-weight)
.POWER SUPPLY: 110VAC OR 220VAC 50 OR 60Hz
.AUXILIARY POWER: +/-14V @ 500MA max
.DIMENSIONS: 160MM(length)*80(width)*52mm(height)
.NET WEIGHT: 0.46Kg
Key Features
• Balance input and balance output design, Hi-Fi sound design
• Multilayer PCB and thickness copper route
• Dynamic limiter inside, suit for proaudio system
• Black-box design, high power small size
• Multi current protection and auto reset system
• Clip signal indicator
• channel PWM running status have led indictor
• Suitable for CE approved designs
• Proaudio system To Hi-Fi design
• Backup DC supply system
SYSTEM TESTING
[FONT=宋]PROTECTION TESTING[/FONT]
ü [FONT=宋]Output shorted testing passed[/FONT]
[FONT=宋]Shorted output wire while half loader running , , good protection performance. [/FONT]
[FONT=宋]No loader and amp running . 1vrms and 1khz signal added, shorted output, protect well.[/FONT]
ü [FONT=宋]Over load testing passed[/FONT]
[FONT=宋]Add 1khz signal and connect 2ohm loader, increase the input gain , if loader power over 400W, SMPSOCP protect will happen, it isconstantprotection.[/FONT]
AP testing below
Sample link below, only accept wholsale order, mass order please conntact our sales.
Aliexpress.com : Buy TAS5630 AND SMPS AII IN ONE BOARD from Reliable smps power supply circuit suppliers on SINEWAVE SAMPLE STORE
G300V33 THD VALUE
Update G300v33 THD value.
G300v33BTL and G300v33PBT have stock now, mini order quantity is 10 unit every order, 120usd/unit,if order more ,please connect out sales. sales @csinewave.com
G300V33BTL LINK:
Aliexpress.com : Buy DSP+CLASS D AMP+SMPS 2.1 OR THREE WAY HI FI AMP WITH ANALOG/SPDIF/USB SOURCE SELECTOR from Reliable amp pc suppliers on SINEWAVE SAMPLE STORE
G300V33PBT LINK:
Thank you for your reply here, please order it in our sample store, if order more than 100units, please send mail to sales@csinewave.comI need SMPS like this attachment..
How much price include to Jakarta, Indonesia
Thanks before
Aliexpress.com : Buy 800W PFC +SMPS POWER SUPPLY , SUIT FOR 2STAGE CLASS H AMP from Reliable power supply dc to dc suppliers on SINEWAVE SAMPLE STORE
Do you plan any open loop digital amps?
TAS5162 | Mid/High-Power Amplifier | Speaker Amplifier and Modulator | Description & parametrics
car all digital 2.1 amp
what a coincidence! our engineer send took two new board photos just now, it is all digital car amplifier design, second version boad debugging now.
Features:
1.All Digital amplifier, use TAS5558+2 TAS5631B+4PHASE DC to DC .
2.10-15VDC input, 150WX2+400WX1 rms power output
3.Support distance remote function
4.Support Spdif and USB audio input
This project will be closed next week,you can send mail to us for the order.
Features:
250w RMS power 100v output transformerless amp module complete
1.250W mono PA amp, RMS power @ 100V transformerless output
2.220V or 110V ac supply selected
3.1u height,330mm(L)X40mm(H)x51mm(W)
4.Self test function, amp have auto self test function, and report amp status to RS485 .
5.RS485 remote standby and mute function.
6.Perfect protection function, High stablity.
4kw rms class D 100v output transformerless amplifier completed!
Customer design one new board , 4KW rms power 100v output , transformerless PA amplifier, Amp case manufactruing now.
robust design, have pass all shorted test and 24hour full resister load testing.
Board size:380mm(L)x300mm(W)x75mm(H)
Sinewave website update now!
Sinewave website updating now! Maybe some area can not login , please conntact sales@csinewave.com or authlxl@gmail.com directly, sorry fo the inconvenience.
Features:
It is closed loop not open
Don't trust this company, they sell incomplete defective products.
Most of which have severe overheating issue
Very very annoyed with my experience with these guys, not only did it take over 3 months to receive my order it is defective and sine wave have provided no real solution
please list your fault product here, and payment message here.
btw, I find this guys private message .copy to here
Default UNHAPPY!
Order NO:61295548206149 Order Time: 20:40 Mar. 05 2014 FREYA KWAN Offline
That is from aliexpress where I buy my amp!
I know you are scammers!
I am going to speak to consumer trading affairs in Australia and get you products banned by customs for failing to meet electrical safety requirements!
we check the order just now, NO REPLY ,NO QUESTIONS, NEVER THREE MONTH. aliexpress forbid us to send goods to you about 3month, or not our sample store will be closed.
please return the fault module to us, we will refund money to u, if you meet problems .please send mail to us , we will help u how to apply .
Sinewave g300v33 DO NOT BUY THIS AMP Bad overheating problem!
I know you sent the amp, My point is it overheats, because there is no airflow in the case!
its a very bad design!
Why are you lying about me messaging you?
I sent a lot of messages about your shotty product!
Why do you sell an amp that has an overheating problem?
You know Im not lying because you quickly came out with a new revision! meanwhile Im stuck with the old revision that overheats!
Please return the fault amp to us, we will refund all your payment. you only order one unit AMP,
If you make it fault or find any bugs, you should send mail to us and we will process it quickly, why no !
Only use one unit amp ! you say 'Most of which have severe overheating issue '
We think most of the diyaudio members are technology, we are quality people!
We only provide new technology high effiency products, any improvement ideas or suggestions are welcome .
if you have, mail us, thank you!
if you met overheat problems, maybe the TAS5630b chip fault.
you ordered one g300v33 amp is the old version, we have update to new version, improve it's EMI performance, it have better over current protection function now.
it have two version:
Stereo module:
http://www.aliexpress.com/store/pro...-SMPS-BLACK-BOX-design/601158_1943380265.html
mono module:
http://www.aliexpress.com/store/pro...-SMPS-BLACK-BOX-design/601158_1953860232.html
we think it is the best solution of TAS5630 we made now, because we offical use this chip from 2007-2014, from 100pcs/year to 5kpcs/years we get rich experiences with this chip now, even we know our TAS5630 amp have shortage still, because TI company team improve these series chip along.
we will find more way to make it perfect.
- Vendor's Bazaar
- Tas5630+smps+aluminum case finished!new year coming!
