Taramps HD3000
It takes the IRS2092S as the drivers for the audio section .
Here are some pics of the amp I have
you'll see voltage across the speaker terminals as it has no negative rail so 0 is half of rail. I do not know if this is true in all full bridge amplifiers.
It should do a health check prior to starting up however so you shouldn't see anything in protect or have it do a health check, start and then protect as it should never start unless the fault can only be detected after it gets a green light which is a good indicator on where to look. I could be wrong if it is not like the new versions and doesn't run diagnostics first.
The problem I’m having g is when I power the amp up . I get -29 volts of dc measured directly across the speaker terminals .
The amp will stay powered up for around 2 secs then protect .
I’ve checked pretty much everything and it all tests good .
So wondering where I go from here
Is there a Q2 in sot 23 (BC817)? If so, can you lift it?
Although i have the schematics of various versions of this amp, i dont have any voltages written down. But its pretty easy to figure out, i mean, this is an older version with no regulation, so there are no variable voltages on the adc.
I ll try to help with this repair.
