I ALWAYS use a tap in a drill.
Set the drill to its lowest speed and lowest torque. Most of us have a battery drill / screwdriver these days.
This results in a more even rotation of the tap.
Hi there,
in my experience, use of a proper tap wrench is the best way with plenty of lubrication. It allows you to feel the tap cutting and stop before any damage is done, like the tap snapping
Use a Taper tap first to start the process, with plenty of oil. As you go progress, after the tap has bitten, turn one whole turn of the wrench forward, and then one half turn backwards. This is important as it crushes the debris generated by the forward turn.
When you have got to the bottom of the hole with the Taper tap, you then use a Plug tap to finish the tap down to the bottom of the hole. (When you remove the Taper tap, use an old toothbrush to clean it) As the Plug tap goes in, do the same "one turn forward, half a turn back" method. again use plenty of oil or cutting liquid.
Did I mention to use plenty of lubrication, when both drilling and tapping?
Kind regards
Mike
Kind regards
Mike
Good point there. Use a taper tap originally, it will find the hole better.
Finish off the thread with a blind tap.
Taps generally come in sets of three.
It is easy to make a hand tapping machine!
Amazon.com: Grizzly Industrial G8748 - Hand Tapping Machine: Home Improvement
You may also note a small dimple in the back of the "T" style tap handles. The is so you can use a live or dead center in the back of the handle to keep the tap aligned. Works best in a lathe doing stock just after you drill it. But you can put a dead center in a drill press and align things to tap square.
I would never tap without a fluid such as "Tap Magic." They do a version for aluminum.
@Mike - that's a good idea starting with a taper tap - I haven't done this often enough, but my first try (20+ yrs ago) I snapped a tap. Still in the sink.
Hi ya Mike, I've been rather busy will e-mail. Kevin
For small tapped holes in ally, especially the more 'cheese metal' variants I usually go over size and use a helicoil insert, much less likely to strip that way.
I'd rather buy a drill press, it serves many other functions.
Taps are first taper, second taper & plug.
First taper has longest lead and is used first.
Second taper has shorter lead and is used second.
Plug is used to finish the threads in a blind hole.
For soft aluminium & brass you can omit the first taper.
Only tap blind if you must.
If you drill deep enough you may not need the plug.
One 'could' simply buy/ use those purpose design 3 lobe screws that self tap.
Drill the apprropriate hole then slowly screw the 'screw' home.
Remembering that were are not building bridges here .
Whaou, that is a lot of information. Thanks a lot for sharing all those information. This is very helpful.
I can have access to a drill press. I will go that way, operating "by hand", and with a lot of lubrification.
All this helps !
JMF
All this helps !
JMF
WD40 is a good lubricant for cutting threads in aluminium.
There are much better cutting fluids for aluminum, which WD40 was never intended for this purpose. Plus, some people are very sensitive to this product when used indoors.
jeff
And by the way, anything better than a hack saw to cut heatsinks to dimension ? I don't find that my "normal" blades cut so well aluminum.
JMF
JMF
Probably because they are meant for steel, and have fine teeth.
jeff
Uh uh...vewwy vewwy cafowy, dis is wocket science!One 'could' simply buy/ use those purpose design 3 lobe screws that self tap.
jeff
Don't spray, use a syringe.
Spray inside a small bottle.
Pull with the syringe. Lubricate with a few drops pressing the syringe plunger.😉
I use bycycle oil, wd40 or other I have on hand. It all works. I gave worked with in a train factory so I know the right way to do it, but the false lubricants works fine also
You need accurate drill bits for tap holes, cheap drill sets may not be accurate enough for tap drills in small sizes. I reckon a hand-held drill will never drill a clean hole, use drill press, cutting fluid and practice to find a good feedrate for the material. Don't let the hole clog up with chips, that will cause friction, heat and enlarge the diameter of the hole (and risk breaking the drill).
- Design & Build
- Construction Tips
- Tap aluminum heatsink
