I am looking at getting some Tannoy Autograph Mini drivers for £250 and want to build or buy and reuse some good sounding cabinets, crossovers that filter the original signal at 2.3khz, a low frequency and a high frequency amp.
I need suggestions on where to get suitable cabinets or designs to build; crossovers, HF amp and LF amps or recommendations on where to get them as either kits or pre-builtI. I am looking for suggestions and opinions.
Thanks,
Philip
Thanks,
Philip
That's the one with the 4.5" dual concentric driver - right?
If so, the specs of the original passive speaker may be helpful: https://upscaleaudio.com/products/tannoy-autograph-mini-loudspeaker
I now see you had another thread on the suitability of the drivers, in which you decided not to pursue their purchase.
i believe this is thread #3.
I expect the LXmini XO kit would be a good choice for active. 1st or 2nd order should be sufficient and the EQ section is likely needed (you’d have to figure out what that EQ needs to be).. Knowing what the factory XO looks like ewould likely help.
Quite a range of amplifiers possible, what do you have spare?
For a cabinet design, the T/S parameters will be needed. As to cope\ying the Tannoy boxes i have not been imressed with them.
dave
dave
@planet10 , sorry to necro this thread, but I found most of the crossover values as follows:
https://www.hifiwigwam.com/threads/help-figuring-out-tannoy-autograph-mini-crossover.111526/
Three questions. Firstly, why the Linkwitz XO? This was one of the responses received in terms of pairing it with the Tannoy Autograph Mini drivers when it was raised as a possibility, based on the information you've provided here.
Second question, other people seem to advocate running the Autograph Mini drivers with MiniDSP 2x4 HD. What are your thoughts on that?
Finally, third question, if not the default enclosure parameters, what type of enclosure for a 4" driver would you recommend? Or does this require measuring the frequency response of the driver, and adapting accordingly?
This is an analogue active crossover designed by Nelson Pass that has a crossover frequency and response curve specifically tailored to match the LX Mini speaker. Looking at the response curve in Nelson's article, the xover frequency is about 750 Hz. As I have already said once in this thread, the Autograph Mini drivers need the xover frequency to be around the 2500 Hz mark (Tannoy actually uses 2300 I believe), so this design would be totally unsuitable for use with the Autograph Mini drivers for that reason alone. The carefully crafted frequency response of the crossover as designed would also not be a match for the Tannoys. You would be wasting your money if you took that advice.
Three questions.
Are you a member… can you grab the XO diagram and post it?
miniDSP woul dbe one way to biamp.
dave
@planet10 , thank you for your response! Admittedly, I don't really know what that means, and I am of the impression that the crossover may need to vary significantly if I go for a different enclosure size.
My impression is that you said you weren't impressed with Tannoy's default offering, and I was curious to hear what other enclosure you would potentially recommend for these 4 inch drivers.
It should be noted the 'XT Mini' crossover schematic is for a cheaper (but similar-ish) speaker in the Tannoy series, as compared to the Autograph Mini. The idea was that with both being dual concentric, perhaps there would be similarities in the design.
However just about everything else relates to the Autograph Mini and its crossover.
@planet10 , sorry to bother you once more, but two questions.
1. What kind of enclosure did you have in mind, when you originally mentioned there could be better enclosures for the Autograph Mini drivers than the original enclosure?
2. Do you reckon a bookshelf speaker made with the Autograph Mini drivers would be better than the BBC LS3/5A design?
Something like this one i did for a KEF 4” Uni-Q.
Is there T/S info on the baby Tannoy?
It is not too hard to beat LS3/5A. The XO is quite key.
dave
dave
No T/S info on the baby Tannoy, unfortunately.
That said I'm looking to take more proactive steps with my bookshelf speaker quest and am finally thinking of giving this a go.
If you sell CAD files for the type of enclosure you've recommended, let me know how I can go about paying you for those. Thanks in advance!
Additionally, one of the DIY speaker building enthusiasts on the forum kindly provided some measurement data for the baby Tannoy drivers to me:
Piston diameter 95mm
Re: 4.745 Ohms
Fs: 90 Hz
Qts: 0.59
Qes: 0.67
Qms: 5.14
Le: 0.504 mH
Mms: 6.797 grammes
Vas: 3.25 Litres
SPL 1w/1m: 87.4
Re: 4.745 Ohms
Fs: 90 Hz
Qts: 0.59
Qes: 0.67
Qms: 5.14
Le: 0.504 mH
Mms: 6.797 grammes
Vas: 3.25 Litres
SPL 1w/1m: 87.4
dave
If you don't mind, I actually tried to send you a PM to enquire about paying for the enclosure CAD files, and it says I do not have the permission to send you a DM. Reckoned in case my previous two messages didn't send a notification through to you, I've quoted your reply if that's not an issue. Thanks in advance!
dave
Good afternoon Dave,
Hope you've had a lovely week.
I've shot an email over to you.
If you have any further questions, please let me know.
Thanks in advance,
Kindest Regards,
Zaiden
I have that email, and the same T/S i grabbed from this thread. Just need to get at my modeler.
dave
dave
OK, looks like it would work in a miniOnken alignment in boxes from 5-9 litres, 7 litres looks nicest.
7 litres is also about the right size for sealed.
The miniOnken extends response downwards by about 15 Hz F10.
dave
dave
dave
Morning Dave!
Thank you so much for your response.
Out of interest, what would make the MiniOnken work better than the UniQ 4" KEF Ken-4T OV8 for the mini Autograph drivers?
Also, I went onto your website and would like to purchase a MiniOnken planset but it does look like there's lots to choose from. Is there any particular one, close to a 7 litre dimension, that you would recommend?
Thanks in advance.
I don’t think i have yet released a 7 litre miniOnken for anything yet,
KEF-Ken is a 5 litres miniOnken IITC, it could probably be squeeze into that box. Just checked it can, same ultimate extention, the larger enclosure should have moire mid-upper base punch.
dave
dave
- Design & Build
- Construction Tips
- Tannoy autograph mini active monitor cabinet, crossover, HF and LF amp build
