Hi All,
This is a schematic for you to critique it. As you can see I don't have a b+ or bias point for the output tube yet nor do I have the plate load set yet as this info will be found by experimentation do to the none audio use of this tube.
http://images35.fotki.com/v1132/fileQcc8/a51b0/1/1298405/5925102/rev2.jpg
Thanks,
Nick
Thanks,
Nick
Then why design a driver for it? First things first, you have to know what the drive requirements are, then you can rationally work backward to the input.
edit: If this is an Eimac 6C21, you'll need a PILE of power and swing to drive it. A 6SN7 won't even tickle that puppy.
http://frank.pocnet.net/sheets/088/4/450TL.pdf
Yes I have. The only diffrence is I'm using machelett tubes not Eimac. Also I'm going to be running it in class a1 and the reason I haven't done the work yet is it's too dam cold in my garage here LOL. But thats what I get for living in New England.
So excatly what suggesions do you have SY do you think I'm going about this all wrong?
Nick
Nick
- Tubes / Valves
- Take a look and let me know what you think
