TABAQ TL for Tangband
Hi Folks,
Bjorn, the 4" indeed works great in the folded TABAQ. I completed the build a few months ago and am amazed what that cabinet does to the TB4"....I wouldn't have believed it were I not to have heard it myself. (I previously had the TB4 in a .25cf bass reflex cabinet and the results were nothing to write about.) That is what peaks my curiosity about the said TB5" which I already have.
If you'd like to share your design for the TB5", I love to see it and I may indeed attempt the build.
Mario
Bjorn:
Throwing out an idea here. Am thinking of using the TB W3-881SI [which you have already determined will work well here] for the TABAQ folded T-L but with a twist.
What if we use 2 of these drivers per side in line with Danny Richie's trick posted here. What would change with respect to the folded T-L enclosure? Can I request you to please simulate this? Might make this design a little bit more "hi-end" than it already is. ;-)
Hi Mario, the TABAQ works very well folded. You can place the driver in the middle of the front if you want - as well as you can mount the driver 5 cm higher in TABAQ.
http://www.coolcat.dk/bjoern/TABAQ BOX Cabinet build.pdf
Please also find attached a way to use TABAQ as PC Speakers.
PS: I am now going to build TABAQ MICRO with TB 2 inch drivers 🙂
Hi from
Bjorn
Hi Bjorn: In India we are starved for speaker drivers but I have found a local manufacturer [http://www.iwaispeakers.com] and they seem to have a promising FR driver which might work well in the TABAQ:
4" Driver
Nominal Impedance 8 Ohms
Resonance Frequency 110 Hz
Power Handling {IEC-268-5C} 25 Watt
Long Term Power {IEC-268-5L} 75 Watt
Short Term Power {IEC-268-5S} 125 Watt
Sensitivity (2.83V/1m) 90 dB
Resistance (DC) 5.5 Ω
Qts 0.81
BL 3.8 T-M
VAS 1.44 Liters
Can I please request you to simulate this and see if this would work in a folded T-L?
Thanks! in advance.
-\keith
4" Driver
Qts 0.81
BL 3.8 T-M
VAS 1.44 Liters
Thanks! in advance.
-\keith
Got revised parameters for the driver from the manufacturer:
Nominal Impedance: 8 Ohms
Resonance Frequency: 100 Hz
Power Handling {IEC-268-5C}: 25 Watt
Long Term Power {IEC-268-5L}: 75 Watt
Short Term Power {IEC-268-5S}: 125 Watt
Sensitivity (2.83V/1m): 88 dB
Resistance (DC): 7.4 Ω
Qms: 2.81
Qes: 0.85
Qts: 0.65
BL: 4.69 T-M
VAS: 3.18 Liters
