T-Line for Dayton Ref 8" (RS225)
You know, this tweeter could give you some great performance for much less cost than the Aurum Cantus ribbon: http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=275-035
With a 3.5 khz 2nd order crossover, I believe it would be a great match for the WR125s. Check out Zaphaudio.com for some evaluation of both of these drivers.
http://zaphaudio.com/4.5test/
Also, http://zaphaudio.com/tweetermishmash/
An alternate to that ND20TB is the ND20TA, which might take less work in the crossover. I've been itching to give this combination a try- the WR125S, possibly in an MTM, with a tiny neodymium tweeter. The drivers have great Xmax so they can play low enough to cross to just about any woofer, yet are small enough to have tight center-to-center spacing.
I guess my dream setup for higher output on the WR125s would include the Vifa D26NC55 as the tweeter in an MTM arrangement with a lower crossover point than the ND20TB would allow. Unfortunately these tweeters are discontinued, so even if I got them now I'd be out of luck on future replacements.
This looks like a fun project- so please let us know what you do.
