I recently purchased this power supply:
Acoustic-Fun
It has two taps: 5V dc 2A and 12v dc 2A
The 5v is great for usb/spdif converters, etc, but I am struggling to find a tripath amp that will run on the 2A put out by the 12v tap.
Does anyone know of the correct t-amp to use that would manage on this supply for use at low listening levels?
Acoustic-Fun
You bought a $250 power supply to power a $20 "T-Amp"?
Any board based on one of these Tripath chips will work.....
TA2020
TA2021B
TA2024
TA2020
TA2021B
TA2024
haha no - I bought it just because it is useful! the 12v can also be toggled to 15v.
but yes, I am now struggling to find something that it is useful for OTHER than usb/spdif converters!
If 2A is sufficient, what is the reason most of the t-amp manufacturers package their amps with >3A supplies?
On another note, how *is* a 12V, 2A or 15V, 2A linear power supply best put to use?
like i said, I had a usb/spdif converter that needed a good power supply, this seemed like a useful device (and it is) so I bought it assuming it would come in handy trying a bunch of other products
all i am asking is about the necessary current to power a t-amp, carts are still necessary even if horses are arguably more important....
any other suggestions of audio gear (preamp, dacs) that might use such a power supply are also welcome
"What is the reason most of the t-amp manufacturers package their amps with >3A supplies" - you should ask the people on the Sure T-amp thread why they are using 350W power supplies.
2A is sufficient, but I like to have a power supply capable of (max amp power output) * 2 watts. It's all personal choice.
Here's a Sonic Impact T-amp being used with a 1A adapter:
Sonic Impact T-amp review
It'll work! I've used 12V supplies with 1, 1.5, 2W to power Amp6-es (TA2020 IIRC). It was fine.
If you notice distortion, dropouts, or noticeably lacking dynamics in the very peaks, you could try upgrading the supply – but only after adding a few thousand uF of cheap capacitors. That should be enough.
OK - thanks guys, appreciate the help.
i assume it is safer to buy the lowest power TA20** amp, ie. the 2024? This way the 2A should be sufficient.
I'm using these 90dB/W/m floorstanders:
Welcome to AudioDirect
with this preamp:
CEC DX-71MK2 Pre-amp Digital Analogue Converter
so it will be interesting to see how powerful the 2024 chip is.
by the way - if, however, 2A is not enough - I can just use a 12V SLA battery, how many amp hours would be necessary to ensure a good 5 or 6 hours listening session?
with this preamp:
is it possible to use a multimeter to measure the amount of current a T amp is using at any given time?
Yep, you will have to connect your multimeter in series between the power supply and the load (your amplifier). Most multimeter's have a 10amp DC current setting.
- Class D
- T-AMP for 12V 2A Lineear PSU
