Synergy Horn with Heil AMT
So this is a success! The test print turned out really well. The only unknown now is how the two halves will match together.
The 3FE22 would be a separate part that would be fixed to the adaptor, the port would go through. I have no idea on the size and shape of the port, I would need some help with that.
I do not own any TPTs, so I have not considered any project with them. They are kind of expensive compared to the ESS AMTs.
That looks terrific Pelanj! Great work.
If 60x30 is the best to go for for a Synergy horn, then that is what I will aim for if I build one too. I might just have to aim for closer to 500Hz pattern control rather than 385Hz as a 385Hz horn is more than 80cm wide!
