Synergy Eggstravaganza
I decided to give this project a try again, but I wanted to see how big I could go. So I'm going to see if it will work with an 8" woofer and a 3/4" tweeter. It is possible that the 8" won't be able to play high enough, while firing through a phase plug. Then again, maybe it'll work. I figured it's worth gambling $25 worth of ABS to find out.
Woofer is a B&C 8NDL51, tweeter is a Tymphany NE19VTS
Reactions: Scholl68
Looks great but how are you going to keep the wires to the HF from rattling/buzzing against the LF cone? I suppose you could hot glue them....
Yeah I hadn't considered that lol
In particular, the leads on the Tymphany NE19 are flimsy and they go straight BACK, right towards the cone of the woofer. And I can't solder them because they're too fragile. Also, I failed to include any route for the wires to exit.
I have a tiny BMS compression driver here, that may be a better option.
Here's the NE19 VTS, note the leads go straight back
Here's the BMS 4526HE. The set up of the leads is just about perfect.
by looking at the wave guide seem hollow, would it creating any trouble?
Lately I printed 30% infill.
Yes, definitely a problem. I apply liquid nails for subfloors to the inner surfaces of all my 3D prints.
If you don't, the drivers will radiate some sound right THROUGH the walls.
It's mostly a problem with midranges and midbass, not so much with tweeters.
Liquid Nails for subfloors makes the enclosure airtight. I use 10-15% infill.
Patrick, have you finished the 8" version? I have a pair of 8PE21s that could work in these when used with a sub. I got inspired by this and DSL speakers and I have an idea to expand this a bit more into a larger synergy horn - like SM60 or into a monitor like speaker like Studio 1. I think it would look terrific with a supershape ATH generated horn. By the way, I print all prototypes in PLA as it is very easy. I need to learn PETG once I get over the prototype stage.
And I wonder if this could be taken into extreme with the large ESS AMT as the front tweeter or with a modified Beyma 12XA30 coaxial, as these two are the best speakers I have heard until now.
Hm, I need to update my (already long) list of potential projects🙂
Could you please show vertical and horizontal cross section of the model? I think I have an idea how it looks inside from the pictures you posted, but I would like to have it confirmed if possible. Thanks!
Edit: I can actually see the cross section from the unfinished print🙂 The channel between the HF part and the shell is constant width?
