symmetrical conical rectangular th
Hi epa,
Looks like this will become a nice thread 🙂.
I just took a look at your AkAbak script in Post #1, and there may be some errors in it.
In the keyed in schematic the driver should return to the horn @ node 19.
In the script for 'Horn segment 10' the nodes seem to be wrongly assigned, and the Radiator should not connect to node 19, but to 20? Also, you seem to missing a 'Horn segment 12'.
I'm no AkAbak expert, maybe somebody who knows what he's looking at can take a look at this.
Just started spl testing on first cab, no question...it's a real sub by golly 😀
My chosen method & tools: Cheap voltmeter, Radio Shack SPL meter, Apex 220 reference mic, Behringer mini mixer for mic pre, SmaartLive, QSC RMX 2450 Amp (the same one that will be driving these when installed). Used voltmeter to set 28.5V to the speaker at 100Hz, took reading with rat shack SPL meter at 10meters, 6" off of the ground (just above the grass) to establish a baseline & calibrated Smaart to that fed by the Apex in the same position, on a stand, 6" off of the ground. After that initial calibration I'm merely toggling frequencies in the generator & logging the readings. Not exactly lab accurate, but it should give usable real world numbers, right?
I will also hopefully have enough time to log one of my Cerwin-Vega T36-750 cabs in the same sitting to give a 'brandX' comparison. Ideally I'll post these results later tonight, right after delivering & installing these so I can also give subjective impressions of them in their final resting place playing music.
Remember I built two of these at once. The first one involved all of the figuring out how to actually build, miscuts & recovery, & the like that comes with my occasional carpentry. The second went together to the actual spec...so cab 1 is solid & respectable in appearance, but tolerances were tighter on #2...#2 is louder across the spectrum, but both behave very well in subjective listening (no huffs/puffs/growls/farts/burbles/other sonic complaints). In fact, they came out wonderfully & they absolutely exceed the modest requirements of the venue.
Here are the SPL test results:
calibrated to 28.5vrms @ 100hz measured at 10meters
Hz dB
cab1 cab2 CV T36-750
25 80.9 83 79.1
26 82.5 83.5 80.6
28 84.5 85.9 83.4
30 87.7 87.8 85.5
32 88.8 89.7 87.6
35 92.2 92.5 89.7
37 96.3 96.5 92.6
40 101.1 101.6 98.1
43 102.4 103.6 97.5
45 101.8 103.5 97.5
46 100.8 103.1 97.1
47 101.1 103.2 96.9
48 101.7 104.2 99
49 102.3 105.1 100
50 102.3 104.7 101.1
51 101.2 103.9 101.6
52 100.6 103.3 101.7
53 100.7 103 102
54 100.8 102.9 102
55 101.4 103.3 102.6
56 101 103.2 103.1
57 100.6 102.6 102.9
58 100.3 101.9 102.1
59 100.8 102.2 101.5
60 101.2 102.8 102.1
61 101.7 103.3 103.1
62 102.8 104.2 104.3
63 103.7 105.2 105.5
64 103.5 105.2 106
65 103 104.6 105.3
66 101.5 103.3 105.2
67 100.6 102.3 104.6
68 101.4 102.6 103.7
69 101.6 102.9 102.1
70 102.8 104.3 101.7
71 104.2 105.8 102.5
72 106 107.6 105.1
73 106.8 108.6 106.4
74 106.7 108.7 106.9
75 105.6 108.2 106.8
76 104.8 107.6 106.3
77 104.1 106.6 105.6
78 104.1 105.9 105.2
79 103.9 105.9 105.5
80 104.7 106.1 104.9
81 105.3 107 105.2
82 104.3 106.6 105.8
83 103.8 106.2 105.7
84 104.6 107.3 106.9
85 104.5 107.2 107.9
86 104.3 107.1 108.6
87 103.7 106.7 109.4
88 103.6 106.5 109.8
89 103.8 106.3 109.7
90 104.3 106.7 109.5
91 104.3 106.5 109
92 104.6 106.4 108.5
93 104.5 106.2 107.8
94 104.7 106.1 107.9
95 105.5 106.7 108.2
96 106 107.8 108.8
97 106.2 108.5 109.3
98 106.2 108.8 108.8
99 105.2 108.1 108
100 103.8 106.9 107.5
101 102.8 106.1 107.5
102 101.7 105.3 107.4
103 101.4 104.2 106.4
104 100.1 103.1 105
105 99.4 102.1 104.4
106 98.7 101.4 105
107 98.3 101.3 106
108 98.2 100.8 106.4
109 98.1 100.5 106.5
110 97.1 98.9 105.8
111 96.7 98.5 105.4
112 96.6 98.6 105.7
113 96.5 98.7 106.4
114 96.5 98.5 106.7
115 96.6 98.5 107.3
120 95.3 96.8 107.1
125 98.4 99.6 107
130 101.1 101.1 106.7
135 105.9 106.3 107.2
140 109.7 110.8 106.2
145 106.6 109.6 104.6
150 102.5 105.8 109.1
And the final pix:
The ubiquitous vanity shot of me relaxing on the fruits of my labor
And last some pix of their final resting place, occasionally they dabble with putting bands on this patio, now they have subs that can support that without issue 😉
Hi epa,
hi oliver.
just like you im not an expert in akabak😀.
did you look at the actual script ,or did you look at the picture.
the pic is missing a few lines.
ill repost it in ful now.
S1 = 900.00e-4; |Horn segment 1 throat area (sq m)
S2 = 900.10e-4; |Horn segment 1 mouth area and horn segment 2 throat area (sq m)
S3 = 900.20e-4; |Horn segment 2 mouth area and horn segment 3 throat area (sq m)
S4 = 1105.00e-4; |Horn segment 3 mouth area and horn segment 4 throat area (sq m)
S5 = 1105.10e-4; |Horn segment 4 mouth area and horn segment 5 throat area (sq m)
S6 = 1563.00e-4; |Horn segment 5 mouth area and horn segment 6 throat area (sq m)
S7 = 1563.10e-4; |Horn segment 6 mouth area and horn segment 7 throat area (sq m)
S8 = 1771.00e-4; |Horn segment 7 mouth area and horn segment 8 throat area (sq m)
S9 = 1771.10e-4; |Horn segment 8 mouth area and horn segment 9 throat area (sq m)
S10 = 1800.20e-4; |Horn segment 9 mouth area and horn segment 10 throat area (sq m)
S11 = 1799.30e-4; |Horn segment 10 mouth area and horn segment 11 throat area (sq m)
S12 = 1804.40e-4; |Horn segment 11 mouth area (sq m)
L12 = 0.10e-2; |Horn segment 1 axial length (m)
L23 = 50e-2; |Horn segment 2 axial length (m)
L34 = 0.10e-2; |Horn segment 3 axial length (m)
L45 = 50e-2; |Horn segment 4 axial length (m)
L56 = 0.1e-2; |Horn segment 5 axial length (m)
L67 = 50.75e-2; |Horn segment 6 axial length (m)
L78 = 0.10e-2; |Horn segment 7 axial length (m)
L89 = 71e-2; |Horn segment 8 axial length (m)
L910 = 0.10e-2; |Horn segment 9 axial length (m)
L1011 = 22e-2; |Horn segment 10 axial length (m)
L1112 = 25e-2; |Horn segment 11 axial length (m)
Vtc = 10000.00e-6; |Throat chamber volume (cubic m)
Atc = 840.30e-4; |Throat chamber cross-sectional area (sq m)
|Parameter Conversions:
Sd = 1225.00e-4; |Diaphragm area (sq m)
Ltc = Vtc / Atc;
|Network node numbers for this tapped horn system:
| 0-Voltage-1
| -Chamber-5-Driver-
|8-Segment-9-Segment-10-Segment-11-Segment-12-Segment-13-Segment-14-Segment-15-Segment-16-Segment17-Segment-18-Segment-19-Segment-20-Radiator
Def_Driver 'Driver'
Sd=1225.00cm2
Bl=24.70Tm
Cms=1.39E-04m/N
Rms=5.13Ns/m
fs=30.9998Hz |Mmd = 164.97g not recognised by AkAbak, fs calculated and used instead
Le=4.60mH
Re=5.00ohm
ExpoLe=1
System 'System'
Driver Def='Driver''Driver'
Node=1=0=5=19
Duct 'Throat chamber'
Node=5=9
SD={Atc}
Len={Ltc}
Visc=0
Waveguide 'Horn segment 1'
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Waveguide 'Horn segment 2'
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Conical
Waveguide 'Horn segment 3'
Node=10=11
STh={S3}
SMo={S4}
Len={L34}
Conical
Waveguide 'Horn segment 4'
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Waveguide 'Horn segment 5'
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Conical
Waveguide 'Horn segment 6'
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Conical
Waveguide 'Horn segment 7'
Node=14=15
STh={S7}
SMo={S8}
Len={L78}
Conical
Waveguide 'Horn segment 8'
Node=15=16
STh={S8}
SMo={S9}
Len={L89}
Conical
Waveguide 'Horn segment 9'
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Conical
Waveguide 'Horn segment 10'
Node=18=17
STh={S11}
SMo={S10}
Len={L1011}
Conical
Waveguide 'Horn segment 11'
Node=18=19
STh={S11}
SMo={S12}
Len={L1112}
Conical
Radiator 'Horn mouth'
Node=19
SD={S12}
exelent results,great job:cheers:
greatz erik
maybe this is it?
doesnt change responce,well as long as we have the numbers right.
DATA EXPORTED FROM HORNRESP - RESONANCES NOT MASKED
|COMMENT: th 18 sound 1400
|REQUIRED AKABAK SETTINGS:
|File > Preferences > Physical system constants:
|Sound velocity c = 344m/s
|Medium density rho = 1.205kg/m3
|Sum > Acoustic power:
|Frequency range = 10Hz to 20kHz
|Points = 533
|Input voltage = 2.26V rms
|Integration = 2Pi-sr
|Integration steps = 1 degree ... 1 degree
|Integration method = Cross
Def_Const |Hornresp Input Parameter Values
|Length, area and volume values converted to metres, square metres and cubic metres:
S6 = 1760.00e-4; |Horn segment 5 mouth area and horn segment 6 throat area (sq m)
S7 = 1760.10e-4; |Horn segment 6 mouth area and horn segment 7 throat area (sq m)
S8 = 1852.00e-4; |Horn segment 7 mouth area and horn segment 8 throat area (sq m)
S9 = 1852.10e-4; |Horn segment 8 mouth area and horn segment 9 throat area (sq m)
S10 = 1852.20e-4; |Horn segment 9 mouth area and horn segment 10 throat area (sq m)
S11 = 1852.30e-4; |Horn segment 10 mouth area and horn segment 11 throat area (sq m)
S12 = 1852.40e-4; |Horn segment 11 mouth area (sq m)
Ltc = Vtc / Atc;
| 0-Voltage-1
| -Chamber-5-Driver-
|8-Segment-9-Segment-10-Segment-11-Segment-12-Segment-13-Segment-14-Segment-15-Segment-16-Segment17-Segment-18-Segment-19-Radiator
Def_Driver 'Driver'
Sd=1225.00cm2
Bl=24.70Tm
Cms=1.39E-04m/N
Rms=5.13Ns/m
Le=4.60mH
Re=5.00ohm
ExpoLe=1
System 'System'
Node=1=0=5=19
Node=5=9
SD={Atc}
Len={Ltc}
Visc=0
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Conical
Node=10=11
STh={S3}
SMo={S4}
Len={L34}
Conical
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Conical
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Conical
Node=14=15
STh={S7}
SMo={S8}
Len={L78}
Conical
Node=15=16
STh={S8}
SMo={S9}
Len={L89}
Conical
Node=16=17
STh={S9}
SMo={S10}
Len={L910}
Conical
Node=18=17
STh={S10}
SMo={S11}
Len={L1011}
Conical
Node=18=19
STh={S11}
SMo={S12}
Len={L1112}
Conical
Node=19
SD={S12}
Hi Trackzilla,
Thanks for the data and the pictures. Very well done. I entered the data from Post #29 into a spreadsheet, and charted it:
