SYMEF PCB
I wanted to open a poll for this.
Assume that you were interested in these PCBs, kindly indicate what would your contribution be to offset the cost of production per PCB 😀
1. Free
2. $3
3. $5
4. $8
5. $12
6. $15
7. $20
8. $25
SYMEF Amp PCB's
I'm interested in the following PCB's for the SYMEF Amps:
Type 1 PCB: Output Transistors not under PCB <---- 4 PCB's
Type 2 PCB: Output Transistors under PCB <---- 4 PCB's
Type 3 PCB: TO3 <---------------------------------- 4 PCB's
Type 4 PCB: SMT <---------------------------------- 2 PCB's just to try working
with SMT
Take care.😀
kindly noted 😀
with SMT
Take care.😀
The list
mrsavage-> Type1: 4, Type2: 4, Type3: 4
passive420-> Type1: 4, Type4: 4
evette->Type1: 6, Type2: 6, Type3: 6
Total-> Type1: 14, Type2: 10, Type3: 10, Type4: 4
We are approaching the numbers where the type1 might get printed first 😉 . Am targeting $8 or $12 per 2oz PCB with the right numbers 😀.
Hi Harrison,
Are you planning a Lateral Mosfet version of this amp? As much as I love the mid high and lower registry of the Symef I built, I somehow think it has its limitations on the upper registry and not faulting your design but mostly due to the limitation of bipolar devices in this area. Mosfets have a tiny bit less presence in lower registry but make it really good in the upper one.
Those are my observations after building many different amps. I read a bit about this after my findings and I'm not the only one who observed this phenomena. However, I must admin, the control you have on the lower registry is tremendously good.
Do
Hi Pinnocchio,
Not yet 😉. Thanks for your observations. We could examine the actual characteristics of that upper registry in the SYMEF thread. The findings might be interesting.
kind regards,
Harrison.
Hi Harrison,
Do
