Due to the number of private requests received for PCBs guess its time for another run of PCBs. 😀😀😀 All in support of the motion say yaaaaay by indicating your interests here.
I wanted to open a poll for this.
Assume that you were interested in these PCBs, kindly indicate what would your contribution be to offset the cost of production per PCB 😀
1. Free
2. $3
3. $5
4. $8
5. $12
6. $15
7. $20
8. $25
1. Free
2. $3
3. $5
4. $8
5. $12
6. $15
7. $20
8. $25
SYMEF Amp PCB's
I'm interested in the following PCB's for the SYMEF Amps:
Type 1 PCB: Output Transistors not under PCB <---- 4 PCB's
Type 2 PCB: Output Transistors under PCB <---- 4 PCB's
Type 3 PCB: TO3 <---------------------------------- 4 PCB's
Type 4 PCB: SMT <---------------------------------- 2 PCB's just to try working
with SMT
Take care.😀
with SMT
Take care.😀
kindly noted 😀
with SMT
Take care.😀
Very interested:
Type 1 PCB (not under) - 4 PCB's
Type 4 PCB (smd) - 4 PCB's
Thank you Harrison.
edit: or $25 towards production. Not sure if I have understood correctly there...
Thank you Harrison.
Kindly noted. Yup you understood well enough, you suggest $25 per PCB 😀 . Thats 2oz US factory direct small quantity price.
Very interested:
Thank you Harrison.
Thanks Evette. How many would you have in mind 😉
kind regards,
Harrison.
kind regards,
Harrison.
include me please,, but not in the smd group
at least 6 of each type except smd,,I don,t care what you charge me these boards are worth every penny. Evette
The list
mrsavage-> Type1: 4, Type2: 4, Type3: 4
passive420-> Type1: 4, Type4: 4
evette->Type1: 6, Type2: 6, Type3: 6
Total-> Type1: 14, Type2: 10, Type3: 10, Type4: 4
We are approaching the numbers where the type1 might get printed first 😉 . Am targeting $8 or $12 per 2oz PCB with the right numbers 😀.
Hi Harrison,
Are you planning a Lateral Mosfet version of this amp? As much as I love the mid high and lower registry of the Symef I built, I somehow think it has its limitations on the upper registry and not faulting your design but mostly due to the limitation of bipolar devices in this area. Mosfets have a tiny bit less presence in lower registry but make it really good in the upper one.
Those are my observations after building many different amps. I read a bit about this after my findings and I'm not the only one who observed this phenomena. However, I must admin, the control you have on the lower registry is tremendously good.
Do
Do
Hi Pinnocchio,
Not yet 😉. Thanks for your observations. We could examine the actual characteristics of that upper registry in the SYMEF thread. The findings might be interesting.
kind regards,
Harrison.
kind regards,
Harrison.
Hi Harrison,
Do
Mr. Harrisson Sir,,In my case you can order whichever type first that you reach your goal, or you can wait until more people join in I would say wait for more. Evette
I wanted 2 of the Type PCB's as well. Take care.
Noted. Thanks.
- Group Buys
- SYMEF PCB
