SX-Amp and NX-Amp
Jim's Audio
Are you listening?
I tried to ask a question on your Ebay listing, but you have set up your Ebay seller account to not accept questions !
Can you supply two amp PCBs and two PSU PCBs? instead of 2+1
How much extra will the extra PCB cost?
Is the postage still correct for 2+2?
Jim's Audio
Are you listening?
Hi Andrew,
He does not really follow forums as he told me before, so I have sent him an email with the link to your question.
Ciao!
Do
No,
the peak is Vpk²/R or Ipk²R
The proper power is Vpk²/R/2 or Vac²/R or Ipk²R/2 or Iac²R
for 500mApk which equals 353.55mAac sinewave the maximum ClassA power is 0.5²*8/2 = 1W
I would not state an instantaneous peak value, unless a specific component needed to never exceed such a value.
and this 1W of ClassA just happens to be -20dB relative to the maximum power of the amplifier.
Nice that we often listen at average levels of around -20db to -40dB relative to maximum power to avoid clipping on transients.
i.e. we often listen in the ClassA mode.
This is where Roender's amp with a maximum ClassA of ~5W (555mA bias giving ~-12dB rel. max Power) excels, we listen most of our time in ClassA.
Further, this may be why you found on listening tests that the amp when biased to greater than ClassAB optimal bias, sounded "better".
The extended range of ClassA avoided crossover distortion for more of the time.
Hi Andrew,
Here is his answer
Thanks for letting me knowing this. The answer is "yes", The addition amount is US$9.50 for the additional PSU board and additional postage.
He can ask me directly on ebay since I do accept questions. I received a number of questions about ovation nx so far thus the setting of this listing should allow questioning.
Please ask him to try to ask question on ebay. Otherwise please PM to him about the about quote, thank you. I do sell two PSUs and two amplifier boards to customers and the above is a standard quote.
Ciao!
Do
I'll try via Ebay again.
But it rejected all attempts to ask a question
We're sorry we couldn't find an answer for you. Unfortunately, this seller is not able to respond to your question. We suggest reviewing the item again to see if your answer is in the seller's listing.
Seems very odd that a Seller does not accept questions and that the Seller claims
which has obviously been overridden by some Ebay setting.
I still can't get past the standard rejection message.
Just noticed that I am linked with Ebay.com
I'll try via Ebay.co.uk in case that is different.
Same result @ Ebay.co.uk and again after logging in to my .uk account.
weird.
Shame to spoil this Thread with a supplier issue.
Can we remove these posts after we have found a way to contact Jims_audio and placed instructions here?
I have asked the Moderators to hold actioning deletion until we find a method of contacting Seller.
If you go down the page to where you see a number counter on the number of visitors to that page you will see where you can ask a question. At first there are a few stock questions that it will attempt to give you previous answers to questions but if you look carefully you will see the line for other questions. I hit that and instantly was able to post a question. I hope this helps those wanting to ask questions. The place to see the number counter and place for the questions is almost to the very bottom of the page and can take a few seconds to load after the initial page load.
We're sorry but we couldn't find an answer for you. Unfortunately, this seller is unable to respond to your question. We suggest reviewing the item again to see if your answer is in the seller's listing.
This message still comes up when I try to continue to ask other question.
He now knows there is a problem, yet has not turned on the "contact seller" function.
He has replied to a personal Email and has not come to this Forum to answer questions.
I could order 2+1, but there will be no method to change the order to 2+2.
Will there be a way to pay the extra $9.50 after "buy it now"?
It would be better if jims_audio opened the questions function.
