SX-Amp and NX-Amp
Other than the feedback resistors and high power resistors, does the dissipation exceed that of normal 1/4watt metal film resistors? I am asking because I want to try the nxAmp with through hole components on a single sided board which I designed a while ago. The changes I'd like to make now is to thermally couple the input transistors. Here is an image of the PCB. Thanks.
Other than the parts specifically noted as high power (the 5W 0.33 and the 2W 33 Ohm) all the other resistors will be ok at 1/4W. However, note Ivanlukic's comments - some of the reasons I prefer to use 0.5W.
I cannot see the detail in your board (layout etc) , but I would thicken up the power and high current tracks - look forward to seeing your final board!
Thank you Bonsai for confirming that 1/4 watt resistors can be used and for recommendations on the board layout. I would have attempted this amp a while ago but for the lack of appropriate heatsinks. Now I am waiting, gathering a list of the corrections between schematic, BOM and the official PCB.
Make sure Samuel that you keep the feedback summing junction compact and close to the level shifting transistors (This is R11, R12-R16, R28, R29). Too much stray capacitance to GND could cause problems - this is a general requirement for CFA topology amplifiers.
Hi folks,
A while back Bonsai asked if I still had any BC546C and BC556C from an earlier group buy when the minimum quantity at Mouser was 10,000. I thought that they had been pitched in a move, but found about 1,000 of each recently on the back of a shelf. If someone wants to manage distribution, the lot can be had for the cost of shipping. Sorry, I can't ship small quantities. These are on a tape with pre-formed inline leads.
Bob
Hi folks,
Bob
I can do that, I already have the mailing addresses for everyone who ordered boards so far, and I think we can ship these in a regular envelope (or try, at least). pm sent
Circuit boards are professionally made, double-sided, solder mask and silkscreen top and bottom side, plated through holes. They are made from Gerber plots provided by Bonsai, the OP of this thread.
PMI,
If there is another board run, please put me down for a stereo set, plus the PSU/protection board.
After Mark Brasfield joined the forum and got folks interested in the LME49713 CF op amp and then Richard Marsh's headphone amp, this really got my curiosity level up and wondered what such an amp to power speakers might look like. Kudos to Bonsai!
It will be cool to learn some things via this thread and the CFA thread. I just restored my Adcom GFA-535 and it's left me wanting to learn even more.
PMI,
Are these KSC & KSA parts applicable to the VSSA build? Just wondering as some of these parts seem to be so coveted here and in other places?
Yes. Same part.
This is partly why I have tried to stay out of the discussion and just read what other people have to say. In the other thread, no clear answer about what is desirable and why, emerged in my opinion. I can read the datasheets just fine, but knowing what makes a difference is another story.
I Can sell 200 pcs of each type.
Do you have a price, how shipped etc?
this was my last post on the subject:
The Fairchild KSC3503ESTU is around $0.80-$0.90 in q 100-250 pieces,
on cut tape, which in my opinion means there is reasonable assurance these are not rejects... US Source, repair stock.
Not sure I understand how price is calculated, there is an internal charge, plus the incremental piece price which makes up the per piece cost. After shipping twice, ~$1, give or take pennies....
Fairchild KSA1381ESTU at Mouser, costs are as follows:
1: $0.47
10: $0.315
100: $0.176
1000: $0.131
So, assuming 100 pieces, cost per pair would be around $1.20 plus shipping. I do not have much more to contribute to the component discussion at this time.
I will leave it up to someone else to decide what is the best solution here. I am not really leaning one way or another.
