The actual version of A1000SMPS can provide both differential voltages in range of +-45 to +-58V, different values on request, as well as single voltage in range of +45V to +60V, other values on request.
Thanks Cristi, I did not know that. Can any of your other SMPS output single voltage +50V?
Hello Cristi, i replaced the thermistor and it works 🙂 The hardest part was to unsolder the old one! Excellent diagnosis.if you can't find-it or is expensive, just let me know and i will send you without charge by letter.
I did not pick the thermistor from above links as the shipment charges are outrageously high. I picked the biggest available from a local vendor. He was not able to tell me how much amperage it would support. As it is 9,5mm diameter, larger than old one, it was worth a try.
It worked immediately : +/-27V output again. I connected to the amp (TDA8920BTH stereo, 8ohms speakers) and it works perfectly for an hour at low to medium volume.
Let's push volume up at 75%. After a minute or two ... sound started to scratch 😕 hum... smoke coming from the thermistor area
I take your offer to send me a 10R thermistor that really supports the load. There is actually room to put a bigger one, up to 16mm if required.
Thanks again for your -post sales- support.
The Vaux is isolated from the main output and can be 5V, 12V, or 15V.
alkasar,
send me a mail with the address and i will send you the thermistors.
the smell is normal in the first few hours since they are getting hot the dust and grease burn-up. after few hours the smell is gone.
alkasar,
I thought it should be but on my board there is a short between Vaux - and 0v on the main output. Does this mean that there is a fault with the board or are there any components that need to be changed in order to isolate the two outputs?
Both outputs are isolated from ground
It is not exaclty a short, there is a jumper between main output GND and aux. GND. in case they share the same GND. if you remove this jumper the aux will be isolated from main output. the jumper have a ferrite bead for HF noise rejection and is between one of the 6800uF caps and one of the 1000uF cap. the designator is R19. simply remove the jumper and the aux GND will be isolated.
Thanks very much! I got the amp and PSU set up yesterday and so far I am very happy with it.
I have it connected up to a power meter and the system uses 5 - 7w under normal listening conditions, but has far more bass and sounds much better than the system it replaced, that used 25w idle.
Aso, a higher power SMPS is under development, but, as we know, it will be available for sale just when will be completed, fully tested and first batch on stock.
Do you mean one can have both (+-45V) AND +50V at same time? How much power can you draw from the +50V, assuming it's used "alone" (I'm asking because this could be an option for DA-1 amp)
The A1000SMPS has by default differential output voltage, but if needed, single voltage can get as well instead of differential voltage. since the transformer can provide 2x50V, by rectifying full-wave the output voltage and has centre tap, a single voltage can also get very easy. if the voltage is in range of 80-120V DC, can use the acctual transformer and the voltage will get between -V and +V ouptuts, and if the output voltage needed is lower, between 40 to 60V the output voltage will get between +V and GND, but a small modification need to be made, the negative reference for the error amplifier must be moved to GND instead -V as it is by default. i can make this modification on request.
Anyway, since i have few more requests, i will make a single main output voltage plus an aux. voltage smps with output power between 500W and 1000W. that one will be suitable for DA-1 amplifiers.
Cristi, can any of your other SMPS provide single + voltage? I’m looking for somewhere between +24v and +35v.
SMPS250 should be big enough – it’s for 2 TC2000/STA508 modules into 8 ohm drivers. I don’t need another AUX voltage, as I can get one off the SMPS500R for my BIPS modules.
Also, is the SMPS500R ok for a TA3020v3b with IRFP4228: +-60V into stereo 8ohm? I’m a bit concerned about the voltage drop you mentioned in another thread: “the A500SMPS use half-bridge resonant topology, the output voltage is not regulated and drop about 10% at maximum power. this is the classic topology used in >80% of the PA amplifiers.” It won’t be run with sine waves or anything, just music.
As fb pointed put, the SMPS250 works fine for TA2022 amplfier. in fact, the amplifier has connections for +V and -V, so the smps can be connected directly there, skipping the rectifier bridge.
the A500SMPS has no-regulated outputs, but the SMPS500R, has regulated output voltage, which does not drop when the current draw increase. it uses LLC resonant topology, with efficiency over 90%.
Just to make sure I got it: the rectifier bridge has to be removed and in its place the SMPS is connected, right?
On the actual version and previous one, since about one year ago, there are connections on the pcb in front of the rectifier bridge for +V and -V. the smps output should be connected to this pins directly and the gnd can be connected to the terminal block, and the bridge no need to be removed.
Mhhh....a pic says more than a thousand words....🙂. I don't know how to insert it here, but perhaps you can provide me with an email address off the forum - thx.
click on
1. go advanced
2. manage attachment
3. search
4. upload
5. submit reply
visually : look at page 4 of the TA2022 webpage pdf manual.Mhhh....a pic says more than a thousand words....🙂. I don't know how to insert it here, but perhaps you can provide me with an email address off the forum - thx.
Top right of the pcb you see -Vcc and +Vcc holes.
You can also look at post #11 of this thread. It has a schematic on how to plug smps with TA2022.
- More Vendors...
- Connexelectronic
- Switched Mode Power Supplies (SMPS)
