Variable output voltage ?
I took a look at the SMPS and linear supply offerings. Any recommendations to obtain +- V variable voltage dual output ? I am looking for V to be adjustable between 30 and 100 Volts dc. I need up to 0.25A from each output.
Cristi, can you post the impedance of the power supplies ?
Even better can you post the graphs for the impedance vs. frequency ?
I don't want to respond instead of Cristi, but this look impossible with any standard SMPS. They use a transformer to fix secondary voltage and cannot be regulated in such a delta. Just little adjustment of the output tension is possible. It would need a special design with not so good efficiency.I am looking for V to be adjustable between 30 and 100 Volts dc. I need up to 0.25A from each output.
Note too that, with a linear regulated supply, you will lose more than 75% of power in heat at 30v if you want a continuous tune of output tension..
In the both situations, things can be better if you allow output to be adjusted continuously between fixed steps. Like in a laboratory PSU.
I just placed an order for an A350SMPS. One bit of info I haven't seen for this unit is the dimensions of it - what space in the enclosure should I allocate for it?
mine is 100x100x35mm. height including pcb.Hi,
same pcb size and holes placement as SMPS500R
Thanks I am just starting to learn about power design. In some switching designs can PWM duty cycle be used to vary output voltage? For the linear regulated supplies, is 25W output achievable ? Sure, 75W of heat would require a good sized heat sink, but if need be I can accommodate the space for that.I don't want to respond instead of Cristi, but this look impossible with any standard SMPS. They use a transformer to fix secondary voltage and cannot be regulated in such a delta. Just little adjustment of the output tension is possible. It would need a special design with not so good efficiency.
Good info to know.
Can you change the SMPS800R output to +-65v?
How much time?
How much extra cost?
Like I asked on Sept 6th:
How much time?
I've had no answer from your company email site either.
Yet another China holiday?
Holiday?
Seems no one answered me neiter.
Not through the website of connex or PM..
What´s going on?
Holidays?
Stefan
What´s going on?
Holidays?
Stefan
My purchase of SMPS800R with +-65v was confirmed by Cristi some weeks back. No extra cost.
Be prepared for a long wait though. For non-stock outputs he needs to order trafos and custom build.
As i said, seems very special with such a range in PWM, but possible to imagine, of course, with a poor noise factor. With Analog, it is 80X0.25 = 20 watts your regulator will have to dissipate. 80, because you need some 10 V of margin to regulate at 100v, so you will dissipate 110-30 = 80v in the regulator. in the worse situation.Thanks I am just starting to learn about power design. In some switching designs can PWM duty cycle be used to vary output voltage? For the linear regulated supplies, is 25W output achievable ? Sure, 75W of heat would require a good sized heat sink, but if need be I can accommodate the space for that.
See : TL783CKCSE3 from Texas instrument. You will need to drive with it a power transistor in emitter follower, because it will not dissipate enough, and think about some current limiter.
yes, but for others not for me 🙁 i was sent by the company for which i work for almost a week in the middle of nowhere to a customer, just because there wasn't any chinese colleague who wish to spend the mid-autumn festival over there. i came back just last night, so, i will prepare and send all what has left from last 2 weeks in the following days. a little more patience will be apreciated.
i will reply to the mails as well, just to find some time. there are 278 mails to this date.....
hey I know how it is,
Maybe you could leave a note on your websites main page when your away so people know what is going on. not always possible I know, but if it is.
It's just an idea we used when we had a website for xbox repairs in New Zealand 🙂.
There is . . . (although not specifically about any particular situation). And there have been plenty of comments here as well. Because of the time required for fulfillment (it's a one man operation) and shipping (China Post, unless you want to pay $50-100 to DHL) you can expect a minimum of 4 weeks and not uncommonly 6 weeks from order to receipt. My last order was "lost in transit" on the first try, and took a full 3 months (no, I wasn't "happy" about that, but I didn't fill Cristi's mailbox with nasty posts either . . . just enough to let him know what was (or wasn't) happening, and he dealt with it).Maybe you could leave a note on your websites
If you can't deal with that then buy somewhere else.
How much time?
How much time?
You can email me privately with the info.
No soup for you!!!
Seriously guys just be patient this is not Christi's full time job. Personally, I think he needs to raise his prices.
Kind Regards,
Robert
Kind Regards,
Robert
No soup for you!!!
Kind Regards,
Robert
Hear hear; I've been thinking the same.
I could never understand why someone which is not completely satisfied of my products or services would want to buy something again. If i would run after money, i should simply ignore the complains and get the cash instead. I've seen in this forum at least two or three other vendors which keep posting in all class D or power supplies threads where they might get the opportunity to sell something, and every time when there is someone in doubt about what should buy, the buy mine, buy mine game starts.
And to be ontopic, i'm working at the voltage versions for all the power supplies, and i will try to make as many as possible as stock versions, to cover almost all the possible request.
For SMPS800R will be a +-60V version with min about +-57Vmax. +-63V. that one could be suitable for what you need. I must repeat, why the range is so narrow, because the topology used can offer high efficiency and good regulation only at the voltage for which was designed, and decrease above or below.
I'm not gonna rise the price, even i have enough orders to do so, i even consider to bring few more models, some lower power versions with lower price than any alternative, including the Moneywell bricks. like i said in another post, i consider to charge extra for custom voltages mainly because after paying few $ more for the desired voltage, would remember easily that it will take some extra time.
In contrast, the price for all the parts had increased in the past 2-3 years, some with 30-40% others even double here on the local market, and if the price for a particular part which is essential rise more than 50% i prefer to not use that anymore than to bargain or pay that price. i hate when i get a higher price tomorrow for the same tomatoes which i bought yesterday. they are from the same lot or manufacturer, and because there is a shortage, the vendors see the opportunity to get some extra-cash. In all these years, the usd had fallen from 8.6RMB to 6.3 and euro from 11 to 8.6RMB
i hate to pay more and i would not gonna do for others what i personally don't like.
I' like to order one of the +-60v SMPS800R.
How do I make such a custom order on your site?
Thanks.
For the moment, to mention the required voltage, just add a note when placing the order. I'm working now at few more voltage ranges which wil be on stock and ready to ship without need to wait as for custom voltages. Also mention if i should solder the IEC cinnector or not.
- More Vendors...
- Connexelectronic
- Switched Mode Power Supplies (SMPS)
