I have the TK2050 Sure board (2 x 100, #AA-AB32181) and the rotary encoder plugs right in.
So I did. And it just blasted sound with no control. Had to quickly unplug the amp.
What's going on?
Here's what I can tell you:
1) First, I'm guessing I have to re-set the DIP gain switches on the board. I have them currently set to "medium" gain.
2) The instructions for either the board or the Rotary Encoder are not all that clear.
3) I've read and observed, there's a push function on the knob of the Rotary Encoder. I don't understand what this is for. Can someone explain please?
Thanks everyone,
Mark
What's going on?
Thanks everyone,
Mark
I think on those you push the button to enable the dial to control the volume. There was some talk of that on the parts express website q&a section.
So, maybe the sound blasted because I was sort of bypassing the Rotary Encoder (by not pushing in the button)?
I'll have to try it on a set of junky speakers.
Mark
Mark
I hate to sound dumb, but if I do that (unplug the speakers), how do I know the thing is working properly or blasting again?
Mark
leave the speakers unplugged and try the push-turn down first. then plug in the speakers......
Mark
I was thinking of unhooking the speakers, press the dial then turn it down,plug in a cell or mp3 player and turn that down as well, then attach speakers.
You might also be able to test with a meter (but I think you would need a dummy load)
Hi Recurve,
Oh, I see. I didn't get what you were saying before.
Hmmm....well, I may have damaged my rotary encoder. Yesterday I set all dip switches to off, hooked up the encoder, and hooked up junky speakers to the amp. I didn't see my LED on the amp light up as normal. Pushed the button on the encoder. Didn't notice those LED's going on either. And I thought something was starting to smell hot, so I just pulled the plug.
I may try everything again sometime, but for now I'll just use my Nelson Pass B1. It sounds fabulous with the TK-2050!
Mark
Mark
- Class D
- Sure Rotary Encoder implementation
