Well done!
Did you try, just for kicks, to put the original '817 back in? I can't imagine a mechanism that would make it to blow in what you described.
Jan
Hi Jan,
As of the last few days:
In the bottom bank the AD817 gave the same volts as the line (i.e. unregulated).
Top bank was giving 14.5 V.
Swapped the bottom bank AD817 with the top one and the top now ran at 9.6V (or there abouts).
Bottom bank with top AD817 gave 14.5 Volts.
Swopped back again - same issue.
Reversed AD817's again - same results.
Also removed the ICs then chacked the +/- input of each IC (around 7.5V) so I guessed the components were installed properly (also did avisual check before that in the first instance)
(BTW, I'm feeding the DC in via a separate AC/DC LM317/337 adjustable converter)
Received the board months back and when the bottom bank gave problems I put it aside 'until later'. Might have added the one return short for each bank before the second one - when I realised my mistake by not shorting the line/return at the connector.
I think either the in+ or in- pin on the AD817 became faulty - although perhaps it was faulty on receipt.
Not sure.
Anyway, it's now working OK.
BTW, because of R15/R16 @ 100 ohms, the two 'legs' of the voltage divider R6/R7 and R13/R14 are not identical so working with 1K resistances for R6/R13 I think R7 & R14 should be 1k1 for 15V output?
Cheers!
