It may not be reliable but may work well enough to allow you to determine if there are any other problems.
LM393
1:7.22
2:2.25
3:0
4:0
5:1.68
6:4.13
7:0.10
8:13.91
LM293
1:-0.01
2:-0.01
3:0
5:0
6:0
7:0
8:0
1:7.22
2:2.25
3:0
4:0
5:1.68
6:4.13
7:0.10
8:13.91
LM293
1:-0.01
2:-0.01
3:0
5:0
6:0
7:0
8:0
It looks like it shut down the power supply,
Double-check the outputs to see if you have any with broken legs.
I see that there is a bad driver IC as soon as i remove the board amp powers up perfectly .
Im changing the driver right now to see what i come up with
Something on the output driver board is defective Since i put the other
KA78T12 in the amp will Draw excessive current with the driver board in.
- General Interest
- Car Audio
- Sundown SAZ3000
