Sundown SAZ3000
Ok im not all there today. I had the red probe on the positive terminal not the negative terminal
Heres what i have on 3 of them there are 6 total
TL072
1:-.02
2:-.01
3:-0.2
4:-14.38
5:-.02
6:-.02
7:-.10
8:14.68
The other 3
1:.01
2:.01
3:0
4:-14.38
5:.01
6:.01
7:0
8:14.68
When i first got this amp in the guy told me it had no output. I opened the amp up and found broken legs on the rectifiers I resolder the rectifiers and the amp worked perfect. I gave it back to him he said as soon as he hooked it up it went into protection mode SO he brought it back to me. I hooked it up and sure enough it was stuck in protection. So i replaced the KIA393 amp came out of protection mode.
Then i replaced the regulators and a couple caps that control them.
Thats all ive done to this amp nothing else.
Ok They are 14 pin driver IC's Heres the voltages i have on them Thats with black probe on amps ground terminal ill try the other way
1:-109.3
2:-114.2
3:-115.0
4:-114.9
5:-114.9
6:-114.6
7:-114.6
8:0
9:0
10:0
11:-02.6
12:-02.6
13:-02.6
14:0
The voltages on the other Driver IC is the same as the first
Heres the voltages i have on the 393 and TL494
LM393
1:.10
2:2.56
3:0
4:0
5:1.69
6:4.14
7:.10
8:13.62
TL494
1:.15
2:2.45
3:.08
4:.05
5:1.55
6:3.85
7:0
8:13.63
9:5.38
10:5.38
11:13.63
12:13.63
13:5.09
14:5.09
15:5.09
16:0
I took a D1302 out of a working amp and stuck it in here To make sure that wasent the problem
What's the DC voltage on the LM293/393 on the driver board?
Use pin 4 of that IC as the reference.
When posting voltages that begin with a decimal point, please add a leading 0 to reduce the possibility of an error (on my part). 0.1 instead of .1 ensures that the decimal isn't overlooked.
YUP its not outputing
Black probe on Middle leg
Leg1:35.8
Leg3:0.22
Know of anywhere i can order one of theese? I have 1 here but i think it may be defective also Heres the reading i get on the one i have laying around meter set to diode check
1-2:0.052
1-3:0.001
2-3:0.050
Probes reversed
1-2:0.050
1-3:0.001
2-3:0.052
