Sundown SAE-1000D
Signal is there, the dc volts is also present (should that be or not), depending on which mosfet p-channel or n-channel gate pad, it swings positive or negative.
I understand your explanation, but i just dont know whats causing the fets to be heated when inserted, so the voltage on the gate pad is ok?
what should my measurements be across the pads G to D, G to S, D to S and GND to all 3 pads respectively? (rail voltage is +/-60)
