Suitable Heatsink for 3886?
I need to build an 8 channel amplifier for my active dipole speaker. I just picked up 8 of these heatsinks, measures 9.25x4.4x0.5" each. Is one of these heatsinks sufficient for a single channel of LM3886 at around 50watts?
Second question is an asthetic one. I had originally thought of placing all 8 channels into 1 chassis, all paralleled in a row. I've got an appropriate chassis cover from an Anthem tube amp, I'd need to put together a front, rear and bottom for it. Or I could build two seperate chassis' and make them look something like the original Pass Aleph amps. What do you guys think would make more sense from a wiring and layout perspective?
Sean: yes, I got them at Princess 😉 Only $69 all in for 8 of them, thought it would be a good deal.
Jason, yup, that's an original TiBook on my desk. But I deny all knowledge of burning any music disks :cannotbe:
Guess I'm good for 8 channels, maybe more :devily: I might try some parallel combinations for the woofers.
RonS
Yes, mine is the original 400Mhz model. I've uped the ram to 768M, and put in a CD-RW in place of the DVD rom. I need to burn disks for work (photographer).
I had sort of tried to dump it in anticipation of getting a new powerbook, but got no reasonable bites. I'm lusting after a new G5, but am waiting for the second coming. I got burned a bit on a first generation G3 that doesn't properly support more than one HD.
Back to audio now 🙂
RonS
JasonL said:
transducer your not burning a music cd with your burner are you : O )
woot a apple user :" O )
JasonL said:
yup i know what it is. used to have one the 400 mhz with 1-gig memory and dvd drive. i called it a hot pad as it got to hot to have on your lap..
i'm selling my 1 gig tower that i have 2003 model 3 months old to get the new 15" aluminum pb : O )
JasonL said:
email me ..
jasonleaman @ shaw. ca
no offence, but do you ever post anything useful or on-topic?
