Suggestions for complete newb - PC/desktop speakers?
7 ply is better. It will do.
More than a few have built out of solidn wood, but one really needs to know what they are doing.
At this point you just want to get something built, start enjoying the music, and get a base line of understanding for your next build. Once you build 1 it is hard not to want to do more.
dave
Oh, I have no doubt about that! I'm already plotting out the center channel replacement, if this goes well.
How about damping for these? The instructions for the Bloodhound talk quite a bit about damping the manifolds (those are the partial 'walls' between the front and rear faces of the box, right?) and certain parts of the box with 1/2" Ultratouch felt or equivalent. Are we talking about this stuff? If so, I can't swing $60 just for sound damping material, what other options are there? I did find this, but it's 1" thick. Would that work with some adaptation?
I'm assuming that whatever we use must be considered acoustically transparent, since it's taking up considerable space in a fairly small enclosure?
Thanks Mike! That got me thinking, I saw on another thread that those magic eraser foam blocks could be used. Would that work here, or wrong application?
I can get a huge pack of 50 for about $10.
I don't know anything about the magic erasers. Are they impregnated with anything? For the price, it might be worth trying if you can get to the inside of the cabinet to change if they don't work well.
The 1st ultraTouch link is for the wall insulation, you are looking for the felt. The 2nd link is exactly, except for the thickness, what you are looking for. simialr can be had in the specified thickness sold as hot water heater blanket material with a thin foil layer on one side and as an hvac silencing matriel with a then black layer on one side. The 1st might be available in small quantities, the 2nd maybe not (i bought in 100 foot rolls).
The 2nd could be used as is, but you might find more bass attenuation than desirable, I have seen where X described the magic erasers and if true they would work… i figured it would be worth buying some to experiemnt with. but given he was the one who’s recommendation had me try the dissapointing TC9 i always take his results with a grain of salt — he has done some very good work thou (his practical implementation of a highly tapered half-wave TL for midTweeters for instance, the dagger).
Carpet underlay, if (mostly) natural works well, as an example many early cars (50s-80s?, newer?) are a good source, specialty felts are usually kinda pricey. Poly batting, fiberglass insulation and others work well too. Avoid foam.
And as Mike said
In light of the budget, sometimes we need to do the best we can for what we can afford.
Scronge.
dave
Thanks so much guys.
Orders placed for the drivers, cotton insulation and terminals.
I'll pick up the plywood tomorrow. I have wood glue, screws and finish already.
I think I'll have about what I need to complete this project once the packages arrive!
What's the best way to cut the holes, bevels and recesses for the drivers to sit in?
Looking at the plans for the Bloodhound, it appears that it requires a fairly complex profile. I have a router, but it's table mounted. I can't quite wrap my head around how I'd set up a template or guide for cutting this part.
The best way to do holes, bevels, and recesses is with a router. If you can't remove your router from the table, you can use a hole saw or a jigsaw for the driver hole. A 45-degree chamfer bit on your router will take care of the bevels. If you don't have a chamfer bit, a table saw or circular saw can be used for the bevels. I don't know how you can do a recess without removing you router from the table and using a circle jig. You can buy or DIY a circle jig. Make a DIY Circle Jig for a Router - House One
If you have a table saw or a good straight edge for a circular saw, that might be easier than using a router for the bevels. If you can't get it recessed, it's not the end of the world. It's much better if you can, but it isn't worth not building the speakers if you can't.
Later i was not allowed to build cabinets.
:joker::rofl: A genuine LOL, I love it!
a big-assed rasp works better, faster, with more control.
Well, I do happen to have a B.A.R. in my shop, so that may be the weapon of choice if I don't have a chamfer bit in my router box. I'm gonna go look here in a minute. Does it not tear up the layers of the plywood? I assume you have to cut 'with the grain' so to speak, but still... Let me go see if I have that router bit, it sure would make this all a moot point, wouldn't it?
To clarify, what exactly is the rebate? Is that the bevel on the back side of the front baffle, or the recess that the driver sits down into on the front face?
EDIT: Yep, I have a decent set of bits, including a 45-degree chamfer. I shouldn't have any trouble cutting the holes, assuming I can figure out a way to do the circles cleanly.
