Hi judyb
I really don't spend my energy in a p***ing match with you OK.
If the poster wants me to explain my statements, I will be glad to with him. I do not think you are really interested in what I have to say about speakers at this point. I stand by my previous statements as it is.
Peace out
Peace out
Infinia,
Now don't misrepresent what I said. Nowhere was I asking you to explain your statements. I'm addressing your dismissive language, your not-so-subtle insults towards others, and your misrepresentation of other posters' comments.
Word
Word
Has anyone discovered anything since this thread started? I have discovered the 4" and 5.5" Peerless Exclusives and Seas Excel Nextels, they make really great midranges! At the moment I will be testing the Revelators too.
For a design with more of a strict budget, I'd be curious about the Fane Sovereign 6-100. From the measurements below, it's a surprisingly clean driver, BUT.. that dip around 1.5 KHz kinda kills it. I wonder what's causing it? A suspension resonance maybe?? Anyway, it's like $37. For 200-2000 Hz, it'd probably be quite a bargain for that price..
http://www.prodance.cz/protokoly/Fane_Sovereign_6-100.pdf
http://www.eminence.com/images/azox/Fane_pdfs/sovereign6-100.pdf
And if you think it looks very similar to the Eminence Alpha 6, well.. they're definitely not the same driver, that's for sure! For comparison purposes..
http://www.prodance.cz/protokoly/Alpha_6.pdf
Funny thing is, I believe MSRP on the Alpha 6 is actually $1-$2 more than the Sovereign 6-100. Yep, $35-$40 each. There's a B&C driver with very similar performance, actually worse in some areas with a horrible breakup.. for well over $100 each. Ummm.. I think I'll take the Fane, lol.
FWIW, this current spec sheet has considerably different specs/response: http://www.fane-acoustics.com/pdfs/Sovereign6-100_SpecSheet.pdf
GM
GM
Agreed, I've noticed that too. As for T/S parameters, you're right, they're usually closer than that.. especially Eminence, and I'm pretty sure Eminence had a hand in that line of drivers, or maybe all of Fane drivers.. especially since they're distributing them in the US.. From the main page, "Eminence is now the Exclusive Distributor for Fane in the US". All of Fane's spec sheets are very similar to those from Eminence, too. As for the measurements.. although T/S parameters are usually pretty accurate (not in this case tho), the Eminence graphs are usually very smoothed and often completely different from what I've found, but not always. I usually don't pay much attention to their graphs though. If you compare measurements from that Czech website to other manufacturer's spec sheets, like B&C for instance, they're usually a lot more similar. With Eminence tho, only some slight resemblances can kinda sorta be seen with other measurements. I've never really understood it either, but it obviously makes a lot of the drivers look better than they are.
Anyway, I realize that 6.5" Fane probably wouldn't be considered in a thread with "Suggestion for the best cone" in the title, but I just happened to be looking at it again when I saw this thread popped back up. Quite a few people around here have messed with the Alpha 6, this one might be quite a bit better though. Also, the top end could likely be improved further with the addition of a phase plug. And it'd be really easy to do without a mess left on the cone since the dust cap is mounted on the former like that. Maybe that dip at 1.5k could be improved a bit too, but I wouldn't hold my breath.. that is, if that dip really exists, and I'm pretty sure it does.
I've often pondered the idea of getting a couple of these to toy around with and see what kind of performance can be had from them on such a budget. I just might do that soon. Might make a neat little bang-for-the-buck 3-way. Loudspeakersplus.com in the US sells them.
thadman said:The TD6.5M looks rather interesting
Wow! What an ugly driver. It must sound great for sure! The specs look great for a midrange used from 200Hz to 3kHz (or beyond, probably even without a low-pass filter at all). Low mass and well-dampened cone with low Le and copper plated pole piece tends to sound really detailed and dynamic. I think I will try one with the pulp cone and Nomex former.
Very good midrange: Fostex F108ESigma
Crossover design is not always simple: Let say that at 3kHz you have the midrange with 90dB and tweeter has also 90dB. You think it is OK? I think not. Because tweeter has 88db when hearing from 45deg angle, woofer will have maybe 84dB. And the sum at 3m is different.
cotdt said:Wow! What an ugly driver. It must sound great for sure! The specs look great for a midrange used from 200Hz to 3kHz (or beyond, probably even without a low-pass filter at all). Low mass and well-dampened cone with low Le and copper plated pole piece tends to sound really detailed and dynamic. I think I will try one with the pulp cone and Nomex former.
If you have deep pockets, you could try a TD6.5M with AlNiCo and maybe Appollo upgrade ? 😀
I take offense to that. It's like calling someone's baby ugly. 😀 The only picture we have released is of the prototype. It has the epoxy coating on the motor. Normally it would be plated, but we don't waste the time on prototypes. Other than that, it has the large phase plug which some find attractive, others don't. We can do the plugs in solid alum or copper. The copper being more expensive due to the material cost.
simon5 said:If you have deep pockets, you could try a TD6.5M with AlNiCo and maybe Appollo upgrade ? 😀
Considering other alternatives like Feastrex, Fostex, and other wideband drivers, it isn't too bad really. Regular driver is $199 retail. The apollo upgrade on them would be $50-75 and the Alnico would be $75-100 upgrade.
John
Didn't you know? Everybody's baby is ugly but their own.John_E_Janowitz said:
John
454Casull said:Didn't you know? Everybody's baby is ugly but their own.
Let me correct that. Every baby is ugly. Period.
A baby start to look like something after maybe 6 months...
- Suggestion for the best cone for 150-3000 Hz range.
