Hello all! Newbie here.
I am planning on using the TPA3255 in PBTL mode to drive a subwoofer. I need help with a subwoofer filter design though on the analog input.
I am thinking of using the OPA1612AIDR , which seems really nice lol. For some reason though, I can't figure out how to make a simple active subwoofer (100hz) low pass filter. I am hoping for a -20dB/decade drop, but more would be great also.
I would really appreciate any tried and proven circuits, or ideas, tips, etc.
Thanks in advance!
Edit:
Attached is my current TPA3255 circuit. (I know it is pretty rough. I drew it quite a bit ago.)
Thanks in advance!
Edit:
Hello @PRR !
I am not sure I understand your response 🤔 . I am trying to create a low pass active filter (using OPA1612AIDR op-amp) with a cutoff of 100hz and a slope of -20dB/decade (or more).
Hi @wiseoldtech !
Hmmm, so I see that first, the audio in goes to a op-amp for amplifying, then to a op-amp acting like a buffer. The buffer is to prevent audio degrading over longer cables between the main board and the control board. Then, on the control board, the audio is fed to another op-amp that boosts the bass, then to another op-amp buffer for the trip back to the main board.
I have no distance problems, as the audio in and the amplifier are within inches of each other, so I just need to figure out the bass boost.
I have created a 100hz low pass filter using a chain of three RC filters then a BC548 transistor to amplify the resulting filtered audio. This "works" on a kind of subwoofer I have, but it definitely doesn't sound the best. I also know some about op-amps, but not much. I do know enough that I think I am looking for a 3rd order butterworth filter (right?).
A Sallen-Key toploogy is probably your go-to. Search: Analog application note op-amp filter design. Analog has a filter wizard, and Texas Instruments should have one, too.
Someone had a whole PDF book chapter on op-amp filters but I can't find it at the moment. Of you're not sure where to begin, a 4th order Linkwitz-Riley filter could be a good bet. The roll-off is slow for the filter order, but that makes it more stable and will prevent unwanted boom or overshoot.
Those boards are only a foot apart, so no issue with signal degrading.Hi @wiseoldtech !
The whole thing can be built on one board.
Really? Hmmm.Those boards are only a foot apart, so no issue with signal degrading.
I'm a newbie clearly lol. From what I've read so far, I have seen that buffers are useful for stopping signal degradation. Why are they used in that schematic?
Thanks @abstract ! Searching now...
If you look at the schematic I posted, you'll see a Sallen-Key setup on the first IC.A Sallen-Key toploogy is probably your go-to. Search: Analog application note op-amp filter design. Analog has a filter wizard, and Texas Instruments should have one, too.
See, and you lost me alreadyIf you look at the schematic I posted, you'll see a Sallen-Key setup on the first IC.
That first op-amp circuit doesn't seem to be setup like this one (a Sallen-Key filter).
The first one on the left looks like a buffer ( probably very necessary), and the 2nd op-amp is configured as a high-pass, so the resistors and capacitors are swapped around. There is also a slight difference between unity gain S-K filters vs the ones with gain resistors.
Generally, it's not something that can be whipped up in an hour without a high chance of mistakes or reduced quality (e.g. a high noise design). I say take your time, use a spice simulator like LT spice or TINA, and good night from me for now.
EACH op amp is serving a different function, and several are configured for dropping the 'highs' in stages as seen in the print. C214-215-216-217....Really? Hmmm.
Again, consult the schematic to understand things.
Ah, that makes sense! Thanks @abstract , I was a bit confused why they were swapped. I haven't ever used LTSpice before either, so I am going to have to figure that out too.the 2nd op-amp is configured as a high-pass, so the resistors and capacitors are swapped around.
I am trying to understand your photo @wiseoldtech , but it is really blurry, and I'm getting a bit confused 😔.
On a side note, what is a buffer used for in audio?
Ah, that drawing is mis-labeled. The 2nd opamp is a unity-gain Sallen-Key high-pass. I do not know why it says "buffer". As you point out, there's about no reason to buffer between the first opamp and a short cable.Hmmm, so I see that first, the audio in goes to a op-amp for amplifying, then to a op-amp acting like a buffer.
Thank you @PRR for the clarification! That became a befuddled mess.
So if I get this straight, I should be aiming for a unity gain sallen-key low pass filter 🤔?
Ah, I found the service manual @wiseoldtech ! That is strange the schematic in the service manual to a Sony subwoofer would be mislabeled.
Not really strange at all.
Many service manuals have the occasional mistakes - you have to understand that they were written by humans who are not perfect.
Analog design handbook chapter 8
Check out the impulse responses of various filter types. Bessel is really good, as is linear phase to 12dB, but perfect matching with a high-pass to get summing to zero can be tricky. Butterworth might not work very well unless the drivers are closely spaced too cancel out any ringing.
- Analog Line Level
- Subwoofer Active Filter Help?
