Subminiature tubes/valves for Hi-FI
The two of DIY schematics
Reactions: pcardoso73
@Koifarm
Thanks for the reply.
Really impressive work that you have there.
I could see that you use encapsulated transformers. I have always been curious if I should go down the same route and scrap all switching converters I have (1 buck and 1 boost). The other possibility would be to use toroidal transformers.
I just want to make the amp as quiet as possible.
Don't you get hum, because of the heaters being fed with AC?
I found the 6n17 tube very microphonic, that should be great for a guitaramp to get more sustain.
How sounds/works that with 12V anode supply? Or is that a 12v transformer used for output?
Most people prefer the 6N21B to the 6N17B, but I only had the later.
I know that the way I've chosen the symbols is not ideal.
So, the 12V are delivered by an external laptop power supply (I am using a 16V instead). That then connects to the boost converter which will output 220V for the output transformer and valves.
So what is inside the "DC input" rectangle, connects to the "HV 220V" rectangle using the boost converter between both.
Crappy drawing. Isn't it ?
@b_force
I tried, initially, to use a 7806 for the heaters but that thing got really, really hot. Then I had the idea of placing an external power transistor to help the regulator, but never got the balance between the two right. The problem is that, if I use a 12V power supply, I will have 6V drop across the 7806 and both valves are pulling 700mA or so. Finally, I gave up and used a buck, which runs cool. 😎
