sub design
does any one know this sub design what are the pros and cons of using this sub ??
It's just a bass reflex with slightly angled baffles and the only advantage to that is a slight space savings. EAW makes a similar box with more radical baffle angles that lots of people think make it a horn but that's not the case, it was simply designed to pack more drivers into the limited space available at live events.
such a deep manifold/angled baffle design might have some sensitivity boost at certain frequency as cavity has its own volume, thus its own resonance freq. However its somewhere in lowish mid-range area so that resonance peak must be equed down anyway.
Bass horn it is not.
