SU-Z780 Technics new Class A amplifier lights but no sound no relay click
Hi All,
I have had this amp since new in the 90s.
whilst playing some music it stopped suddenly and the VU lights stopped working along with the sound to the speakers.
I turned the unit off. unplugged every thing except the power cord.
I turned it on again and all the lights came on, however the speaker relay has not clicked like it normally does a few secs after pressing the power button.
I took the cover off the unit and looked and smelled for anything burnt but nothing. The main fuse is of course fine as the power is on. There's a large chip(~50mm) and another 15mm connected to the one mammoth heat sink and a Fan off that. I can see the speaker relay ...well the only one there.
Apparently(from the user instructions) there is a protection circuit that resets itself after a speaker short or overload, but that's not helping as I've got every thing disconnected and I cannot see it anyway.
I tried connecting a CD source to the RCAs but nothing.
I tried the headphones jack, but also nothing.
I've read on this forum that the speaker relay might need replacing.
I've ensured that only one of the 2 speaker circuits is turned on.
I've checked that the VCR switch that diverts the input monitor is off.
there is no schematic on the operating instuctions so I am flying blind here.
are there any internal checks that I can make to help identify the components to replace ? like perhaps bypassing the speaker relay ?
thanks guys, judging from other threads, you have a good community here.
pics for post on technics suz780 amp
a few pics to go with the question...
Joined 2009
It sounds like some speaker protection circuit has kicked in, protected your speaker, and is now preventing the amp from turning on.
Try measuring the output voltage of the chip amp itself. You should be able to access this on the relay pins. You'll probably find DC on the output of the chip amp.
Tom
Tom
thanks for the quick response Tom.
is the chip amp the huge one in the centre ?
so basically I'm checking for 24vdc to trigger the relay ?
I'm presuming I get at that from underneath...so removing the board from the casing ?
Shouldn't this be in another forum? This is not a chip amp, yes?
I did a google image search for technics chip amp and a picture of the same chip came up. https://www.google.com.au/imgres?imgurl=http://i.ebayimg.com/00/s/MTA2NlgxNjAw/z/f-8AAOSwmrlUvvkw/%2524_1.JPG&imgrefurl=http://www.ebay.com/itm/Vintage-Panasonic-Technics-AMPLIFIER-for-restoration-or-DIY-chip-amp-projects-/181721955229&h=266&w=400&tbnid=8oU05WBe7ItLtM:&docid=P9UK4h9RvReWcM&itg=1&ei=tOHkVr39KabGmQXFsYiICA&tbm=isch&ved=0ahUKEwi9p_2n37zLAhUmY6YKHcUYAoEQMwgiKAYwBg
I've never heard the term before, but id expect its an amp that has a chip rather than valve or transistors at its heart...but I may well be corrected on that.
Joined 2009
What would you call it? The SVI3205 power amp module is about as chip amp as it gets.
Yep. The black module on the heat sink.
Not really. You'll probably find 0 V at the relay. That's why it doesn't go click. Your task is now to figure out why it doesn't go click. Reasons include:
1) Amp module/chip failure (likely)
2) Over temperature fail (not likely as the amp is stone cold)
3) Failing monitoring circuit or relay driver (not impossible)
I googled "SVI3205 datasheet" and found this schematic (click for larger view). That's probably how your amp is built.
Note the relay driver signal on pin 18. Measure to see if you get the waveform shown (0 V at power-on and -13 V after a 4-second delay).
Also measure the power supply voltages on Pin 4 and Pin 5. You should see a symmetrical voltage, so, say ±60 V as shown above or ±45 V. If you see, say, +45 and -0 V, there's a fault in the power supply.
If the power supply looks good, measure the output of each channel on pins 3 and 6. Should be 0 V.
Measure the voltage on Pin 10 (-15 V -- I wonder where this comes from).
Measure the AC voltage on Pin 8.
It looks like a pretty interesting module. Notice the four power transistors on large metal slugs to get rid of the heat.
Tom
3) Failing monitoring circuit or relay driver (not impossible) -hoping for this Tom.
pin 18 is 0v always.
pin 4 is- 65v pin 5 is 65v
so power supply is okay but I seem to have dc voltages at the pins 3 and 6 which is a good reason why I have 0v at pin 18....but why I wonder.
pin 3 is -55v pin 6 is -42v
any thoughts on these.
Pin 10 is -14.7
pin 8 has 1.1v AC
yep the amp is supposed to run in class B over 20watts but a pseudo class A below.
Tom
Joined 2009
What's the input DC voltage on pins 13 and 15? If you have DC there, you should have DC on the output if the amplifier module is DC coupled (which I don't know if it is).
You should have 0 V DC on the amp input (pins 13, 15). If you don't, we should figure out why. If you do have 0 V on the inputs and get DC on the output, your amp module is fried.
And yep. The DC on the output is the reason the amp module doesn't assert the relay control signal. The protection circuit is doing its job and protecting your speakers from the DC.
Tom
pins 13 and 15 have 0v and -19.6v DC
its not looking good for one of the channels as the zero on 13 shouldn't have DC at its output as you said below
And yep. The DC on the output is the reason the amp module doesn't assert the relay control signal. The protection circuit is doing its job and protecting your speakers from the DC. yes I understood this part...but why the DC on one input
pins 12 and 16 are connected to pins 3 and 6 output channels via the RC parallel circuit. so I measured these as well.
so pins 12 and 16 are 7.1v and 31v respectively. I'm kinda hoping at this stage that the DC at one channel's input is affecting how the other channel generates its output from the zero input on its channel, but I'm just being hopeful.
any thoughts on what next Tom ? I'm thinking one channel is fried...but hopeful the DC on the input of the other channel mitigates this
Tom
Unless something is wrong in the preamp section that causes DC on the input of the amp module (that's doubtful as it appears to be AC coupled), my money is on a dead amp module.
You could try to trace the connections from the input pins of the amp module back towards the preamp/tuner section. If there's a capacitor in series with the input, de-solder the two input caps. Just make sure the amp has a resistor to ground (like the two 39 kΩ shown in the schematic I posted in Post #7). Power up. If still no relay click, the amp module is dead.
You can get the amp modules on eBay. I don't normally advise people to buy components on auction sites, as many of the components sold there are either fakes or more expensive than the known-good parts you get from the distributors directly. In this case, it appears eBay is your main option unless you can find a vendor that has it in stock.
It could also be time to replace the receiver.
Tom
because one channel has DC input, that might be a preamp problem but because the other has zero input but dc output it's likely that that channel is blown.
I've had a decent look on ebay.com and cannot seem to find that chip.
I've tried svi 3205
svi chips
technics amp chips
chip amp modules
I saw online that they are rebadged sanyo STK chips ...so I even tried that.
do you know where I might get them ?
Rod.
I'd try B&D Enterprises: B+D Enterprises - Home page
I seem to have found some Tom.
thinking of the 3206 instead of the 3205 and make sure I get more heat sink onto it.
Just make sure you research the difference. From my brief poking around the other day, I found the main differences between the various modules in the 32xx series to be the supply voltage. You want to make sure the module you get can survive the supply voltage of your amp.
Tom
Adason...a further thought.
armarra1, i would clip the leads to input and output of faulty channel, and see if the other channel works, as a proof there is nothing else wrong.
Adason,
just thinking further,
Are you suggesting that the SVI chip is gone, so just clip the leads of the input and output(as its broken anyway) to isolate that channel and in so doing, open up the other channel to probably working and hearing the relay click and if no change then something else is also wrong ?
