Stupidest questions ever?
Disabled Account
Joined 2023
This might look weird to you guys, but I wanted to confirm it before doing some home-made explosions:
The 0V is supposed to be connected to PIN 3?
IN- is supposed to be connected to PIN 2?
Are all grounds supposed to be on the same network?
I built a circuit very much like this some years ago. Because of the high current load of the speaker, the voltage Vs (with respect to ground) dropped a bit when the speaker demanded current (at the positive peaks of the signal).
The voltage across R2 and C2 is a fraction of the power supply voltage, and is connected to the amplifier + input. The loop thus formed can cause a low-frequency oscillation. When I had that problem, I made C2 bigger which simply lowered the frequency of oscillation. What worked for me was to replace R2 with a zener diode rated for half the voltage Vs. This will bias the amplifier output at Vs/2 (with respect to ground), about where you want it. If battery powered, Vs will drop a bit between recharges or replacements. This will make the constant bias a bit less than optimal for a low battery but a small price to pay for stability.
It could be that my power supply was not "firm" enough; that is, it didn't take much current to change the voltage. You may not have this problem.
Also put C3 close to the chip. Identify high-current paths and use low-resistance (i.e., large diameter) wires for them.
Tom
Reactions: NanoFarad
You don't need Big 5W resistor for R6, 1-2w usually enough. I used 1W metal oxide there. Interestingly my friends destroyed this chip couple of time but i never saw a burned R6. OTOH the value of the output capacitor isn't optimal, you need at least 2200uf or maybe more to get decent low frequencies.
I am taking a guess here, but I bet that I am correct. If you have a 4.7uf electrolytic capacitor in circuit, then often times it is bypassed by say a .1uf or similar FILM capacitor. The film cap will be physically small in size and easily fit on the board.
So some capacitors are electrolytic and others are film.
Reactions: tavares_costa
All caps should be electrolyte?
I was referring to C1 & C3, not C2. Sorry for the mistake.
C1 & C3 could be film or electrolytic, but you won’t notice nor mesure difference for this kind of amp. 4,7uF electrolytics will be smaller and cheaper than film.
C2 is typically an electrolytic, no need to have a polymer.
C4 , 0.47uF, is typically a film.
C6 is a film or a ceramic. If ceramic choose its voltage rating 2 to 3 time the supply voltage as most of ceramics have their value related to the voltage at their terminals.
