Stupid question
Put two condensers in series.
Take two electrolitic condensers, the one that have polarization, put plus with plus, or minus with minus.... two 10 uf units will make a non polarized 5 uF....... also two 22 uf will make one non polarized 11 uf....if big values.... you will have some inductance because internal condenser construction is alike a coil.... this way you put a parallel 0.1 parallel unit with them to guaranteed hi frequency will pass..... coil an make some resistance to hi frequencies.
Carlos
Re: I forgot voltage.
destroyer X said:
When you put two condenser in series, the voltage capacity doubles.
This way, two 10uf / 50 Volts condenser will make one unipolar, or no polarized, of 5uF / 100 Volts.
Carlos
Hardly the point when putting two unipolars back to back.
Two 50V unipolars make one 50V bipolar,
DC ratings, for AC ratings degrade to 35V.
🙂 sreten.
